Old 06-23-2013, 02:09 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Smile Rear bench seat backrest fold down mod
Well here is another take on the Rear Seat Back Rest Fold down Mod. I had been wanting to do this for a while, one of the main reasons was to have a place to set things that i did not want carried on the Rear Seat and also an easy access to the rear window for cleaning of the glass. Well here is what I did.
Took a piece of hard condensed plastic (not sure how you call this type of plastic) and cut 2 pieces, 3/4" x 13" x 2.5" and drilled holes into it, 2 for the bolt area and one for the alignment pin of the seat.
Did the same for each piece and then cut a steel pipe to make support spacers to give the seat more solidity in case of impact.
unbolted the seat and installed the new spacers.
A little anti-seize done not hurt and the rear bolts must be be getting some sort of humidity as they were starting to rust.
Now for the Back seat rest the 2 clips that clip the pins on the back of the cab, the point of this clip unit has to be grinded down about 3/16th I noticed that the cab clips are not even. one is actually angled a bit higher than the other, the reason I did it this way is that if you put a 1" piece on the floor you loose the amount of bolt holding the seat, at 3/4" there is enough bolt to safely keep that rear seat attached. The 3/16th I removed makes it that the clips don't hit the hooks when pulling forward or putting the seat back to its location.
Here is with the seat up
And with it down.
Also, way more easy to clean the rear window now.
If you have questions let me know.
Old 06-23-2013, 03:10 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Nice job on the custom spacers.
Edit: spoke too soon on the rep points haha. Will have to get you back when they let me!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 06-27-2013, 01:12 PM
Ezekielguy86 Ezekielguy86 is offline
Vehicle: 2012 Dodge Ram 1500 5.7 HEMI
Trim Level: ST Express
Rep:71
Ezekielguy86 will become famous soon enough
When I added my fox box it came with these spacers and for the life of me I cannot figure out how to let the back of the seat down. Am I missing something?
Diablo Sport Intune HemiFever 93, S&B Intake, 14" Jones Full Boar, Mag Y Pipe, 180 T-Stat, Billet Catch Can, Pioneer 5500BHS, Fox Box W/ Type R, Air Lift 1000
Old 06-27-2013, 02:42 PM
Vehicle: .
Rep:4373
the spacers may not lift the seat high enough for the back hooks to be higher than the cab area they hook into when the seat is down, Trim off about 3/16th off the 2 hooks that are in the back of the backseat that grab onto the cab. Just unscrew all 4 bolts and lift the seat up to the point where the back rest is at its highest point, usually around 60 degrees, then lift the seat so the back rest unhooks, trim them and then put it back like it was, it should unhook now everytime you put the bottom of the seat at around 60 degrees upward
Old 07-06-2013, 08:19 PM
miamidad miamidad is offline
Vehicle: 2012 Ram Express Crew Cab
Trim Level: LSD, TBCG
Rep:54
miamidad will become famous soon enough
nice job. looks good.
Old 07-13-2015, 12:14 AM
Drako0099 Drako0099 is offline
Vehicle: 2013 Ram Sport
Color: Max Steel
Drako0099 is on a distinguished road
Photos wont load for me....
Old 09-15-2015, 12:22 PM
Old Dodge Guy's Avatar
Old Dodge Guy Old Dodge Guy is offline
Vehicle: 2015 Ram Tradesman
Trim Level: Tradesman
Rep:12
Old Dodge Guy is on a distinguished road
Would like to see photos but they will not load. Whats up??? Have they been taken down???
