Old 06-23-2013, 08:21 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Default Rear end failing. Again....
My rear end is howling on decel. Dope is full, no play in shaft. Amy idea what is going wrong??
This is not the first rear diff issue I've had.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 06-23-2013, 08:31 PM
Rep:2616
any wetness around the rear differential end of the driveshaft ??
any wetness where the axles connect to the wheels, inside or out ??
Old 06-23-2013, 08:34 PM
Outlaw's Avatar
Color: Bright white
Rep:435
Near pinion is damp. Entire back of truck is covered in oil.
[/CENTER]
Old 06-23-2013, 10:33 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Sounds like the pinion bearing...uneducated guess. If it was replaced before, could be it wasn't torqued enough. It's a pita because you have to crush the spacer (sleeve) near perfect to remove the end play. To the inexperienced they may think they have it tightened enough but the pinion will still be loose until they crush the sleeve. It takes the right amount of torque and it can't be loosened if you over torque it. You have to start over with a new sleeve. I think this is the reason behind the pinion nut defects and not from the nut itself. I mean, who put these things together at the plants in the first place? Not to mention, I've seen too many inexperience kids working at dealerships... mine especially. With so many overwhelming repairs and short handed there's no telling who helped replace these things (recalls). Check to see if there is any slack in your pinion gear, just guessing of course..
Old 06-23-2013, 10:38 PM
Outlaw's Avatar
Color: Bright white
Rep:435
It's getting traded off very soon. Even if I lose my rear on it. 4 diff failures?
Not cool.
[/CENTER]
Old 06-23-2013, 10:40 PM
RadioFlyer's Avatar
Rep:146
Not cool.
Who repaired them? I take it you have an open rearend?
Old 06-23-2013, 10:44 PM
Outlaw's Avatar
Color: Bright white
Rep:435
2 different dealers have had their paws in it. And yes open diff.
[/CENTER]
Old 06-23-2013, 10:55 PM
RadioFlyer's Avatar
Rep:146
If you like your truck I would keep it. Talk to the dealership and the tech who repaired it and who is going to repair it. If there is no warranty I would go to the best 4X4 shop around and have them install an LSD of your choice. I know it's a headache, but it not worth loosing the money when it can be fixed right at the right shop and guaranteed.
Old 06-23-2013, 10:57 PM
Outlaw's Avatar
Color: Bright white
Rep:435
At this point I'm just sick of it. I'm ready for a change. Tired of the numerous issues this truck has had. It should have been lemoned.
[/CENTER]
Old 06-24-2013, 12:10 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
3 diff failures here as well. I'm sick of the truck as well.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
