Old 06-24-2013, 01:15 PM
MaxPower's Avatar
MaxPower MaxPower is offline
Vehicle: 2009 Ram 1500
Trim Level: Lone Star
Color: Grey
Rep:84
MaxPower will become famous soon enough
Default Just some pics on installing aftermarket bluetooth
I doubt anyone will have any problems with this, but I swapped out my factory head unit for an aftermarket one. I took some pics and thought I'd throw up what I found in case it helps someone out.
I initially went with a JVC KD-X80BT, but it was slow in how fast my inputs on the factory steering wheel would respond. Plus the radio reception was terrible. I had bought it from Crutchfield so I contacted them and I swapped to a Pioneer DEH-X8500BH free of charge. Gotta love their service. Their kind of high in their prices, but I had gotten a free reward card that cut them down to cheap.
Here's the install. It was all straight forward with using the PAC RP4-CH11 adapter to retain factory steering wheel audio connections. One thing I found was on the JVC you have to splice together the steering wheel input wire, while with the Pioneer you use the included 2.5 mm jack plugged directly into the back of the head unit.
Here's a pic of the mess I made. It was an easy mess to make with 2x some size torx bit for the bezel, 4x 7mm bolts holding the head unit in, and 2x 10mm bolts to remove the driver's grab handle.
Here's where I mounted the mic for the hands free calling. I pulled the A pillar cover off and there was tons of room behind it. I zip tied to the existing wires in it. There was about 3/4" of space at the bottom that was open to under the dash. All in all, it was about the easiest wiring run that I had done for going from the headliner to the head unit.
After that was installed, I put it all back together with a custom cell mount I built (that still needs to be painted in this picture) and it looks pretty good. The sound is great with the Infinity 6x9s I also put in. The unit is fast with cold booting to playing off the 16 GB USB in under 5 seconds. HD radio has been a surprise because I didn't realize most radio stations broadcast multiple streams of programming on the same channel. Hands free calling is working great with the factory radio buttons now being used to answer calls in addition to browse folders, change stations, volume, etc...
For $300 including all the above plus all adapters for steering wheel controls, antennae, single DIN, and factory harness connection isn't bad. Plus I'll give Crutchfield a big plug for hooking up a free return and replacement when I wasn't happy with my first receiver.
Old 06-24-2013, 01:25 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Pioneer has always had great bang for the buck. I currently have a $100 deh3500 that out performs my $150 Kenwood excelon.
New audio build in progress
Old 06-24-2013, 01:45 PM
Rep:2705
Thanks for the write up & pix
So now your microphone is up at the top left corner of the windshield ??
That is where it should be, away from the wind from outside & from the climate control fan noise
not much that you can do about road noise & the persons voice in the other seats
Old 06-24-2013, 01:48 PM
Grubrunner's Avatar
Rep:3883
Yeah great job.
Points from me too.
Grub out!
Old 06-24-2013, 03:24 PM
MaxPower's Avatar
Color: Grey
Rep:84
Thanks for the rep!
Yeah, it's mounted on the top left of the windshield. I used the included visor clip to clip it to the headliner. Initially I was going to put it in the center headliner cluster that has the garage door opener, map lights, and rear window switch. But it didn't look as good and would pick up more on other occupants talking. The current location looks good and it pics me up clearly.
My wife complained of climate control noise when I have recirculation on and the fan at full blast, but I don't think there's much I can do about that. It's a choice of Texas heat or wife frustrated wife that can't hear me. I'm not sure which one will end up making me more uncomfortable....
Old 06-24-2013, 05:38 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Yup, great stuff, nice work, reps for sharing them pics and how you did it.
Old 06-26-2013, 08:52 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
nice mod, and thanks for the write up
Exco
Bill
Old 06-26-2013, 10:04 AM
JimsRamTruck2012's Avatar
Vehicle: 2012 Ram Express
Trim Level: Express Package
Color: Mineral Gray Matalic
Rep:327
You did a great job.
I will be doing something similar when I install my upgraded head unit so the pics may just help me out with this project. That is when I can get around to it.
Old 07-11-2013, 05:40 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Hey nice mod....Nicely done....
Old 07-13-2013, 01:55 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:379
Great job. Way to go.
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Goodyear Duratracs. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector. More AR's than you can shake an AK at.
