Old 06-24-2013, 01:09 PM
mrcool mrcool is offline
Vehicle: 2010 Dodge 1500 sport crew
mrcool is on a distinguished road
Default HID's with DRL problem
I have a 2010 dodge sport with quad light's. I installed HID's in high & low's with relays & anti-flicker modules. They work great but with the DRL on when I turn on the drivers side turn signal the DRL's go put both sides because the harness is plugged into the driver side. With the right turn on both headlight's stay on. This a Canadian truck that turns off the headlight when the turn signal is on. I would like to fix this without wiring in two more relays & two more anti-flicker modules into the passenger side. Any thoughts? Thanks
Old 06-24-2013, 04:52 PM
Asur Asur is offline
Vehicle: .
Rep:4373
What kit / wire harness did you get? I ask because I have not heard of any issues with the wire harnesses from **************** or theretrofitsource.
You could run a trigger wire to the passenger side also, then if one or the other is off they will still remain on due to the second trigger point. Just a thought.
