Old 06-24-2013, 02:23 PM
AcadianRam's Avatar
AcadianRam AcadianRam is offline
Vehicle: 2012 Dodge Ram
Rep:53
AcadianRam will become famous soon enough
Default Help with understanding my trinity T-1000
I got some info from you guys on how to do a log to send to my programmer. But here is a question when I get to the part that says 07-up-hemi and 07-up tuner or something like that which one do I take, mine is a 2012. Now I got a couple of files from my programmer would I put those in the trinity and use one of those
Old 06-24-2013, 02:37 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Those are just Diablo's stock default gauge layouts,
usually there's three pages to scroll through showing all the parameters that will be data logged when you hit the record button.
one is usually more detailed as far as engine tuning and less about monitoring temps etc.
Choose one that shows the most info like timing (spark advance) MAP,
ST and LT Knk RT (Short Term and Long Term Knock Retard) etc...
You can also setup and save your own parameters to monitor and record
based on what Hemifever/White Lighting want you to record and rename it Custom Tune_01 for example.
Old 06-24-2013, 02:39 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Usually your specified tuner requires a list of things he wants your to record what you will have to do is ask for what they want and make your own setup with those different sensors to record for him
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 06-24-2013, 03:09 PM
AcadianRam's Avatar
Rep:53
So the 07-up would be the one I would use even though I have a 2012. Here is what he sent me, would I have to put these in my trinity
attaching a couple logs for reference. a log from your truck will show if you have room for more spark.
the "Air Charge" PID in "0_100_TH" datalog is important, and should be added to the list of PID's logged in "4-11-13 tune,WARM log.K.Wiseman" datalog
Old 06-25-2013, 01:13 PM
RamTex's Avatar
Color: Stone White
Rep:366
I would just use hemi fever or johan from diablo they can talk you through it better i dont know who is doing your tunning...
