Reverse Light wire - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-24-2013, 02:15 PM
RamRod55's Avatar
RamRod55 RamRod55 is offline
Vehicle: 2010 Ram 1500 4x4 Crew
Trim Level: Big horn
Rep:26
RamRod55 is on a distinguished road
Default Reverse Light wire
So I come here to vent/ask a simple question...I have a lightbar that has a wire that be spliced into the reverse light to make the lightbar light white when the truck is in reverse...simple right? Ok so I used a quick splice and spliced into the white wire with the red stripe on it behind the driver side taillight AND....nothing changed. The reverse light is still not working on the lightbar. Am I missing something??
Old 06-24-2013, 05:16 PM
82corvette's Avatar
82corvette 82corvette is offline
Vehicle: 2012 Ram Crew Rambox
Trim Level: Laramie SLT
Rep:128
82corvette will become famous soon enough82corvette will become famous soon enough
You can pick up the reverse power on the trailer connector at the center post. If I remember right the color should be purple. It would be better to connect at the plug.
Old 06-24-2013, 05:53 PM
Asur Asur is offline
Vehicle: .
Rep:4373
If you send a positive to the white wire does the light bar light up the white LED's?
If you take a test light to the wire you spliced into does it light up the test light when you put it in reverse?
you my have gotten the ground wire off your reverse light.
yes you can use as indicated by 82 corvette the center pin of the 7 pin trailer wire, the purple one is also correct
Old 06-24-2013, 06:08 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
I just hooked up a backup camera yesterday and used the reverse wire in the 7 pin harness and it was white with a red tracer. It's possible that they've changed the wiring colors over the years though
OP, I would definitely do what Asur said. Try hooking up the lights to an external power source first to see if they even turn on. That way you can eliminate the lights as the problem. Also, LED lights do only work if they're hooked up one way.... you did hook them up correctly right? Not backwards?....
Old 06-24-2013, 07:40 PM
Vehicle: .
Rep:4373
What brandon said is also correct, it may be different on other years as far as the color goes, just grab pin 7, the center pin you will be good.
Old 06-24-2013, 10:19 PM
RamRod55's Avatar
Rep:26
thank you all for the help. Im new to the "do it yourself" projects on the truck but im learning lol but so on the 7 pin, do what now?? I just go in the back of it and splice to the purple wire that im guessing ill find when i get under and look??? As of now i just have it plugged into the 4 pin with the hookup that it comes with....thanks again for the help i am a "newb"
Old 06-24-2013, 11:01 PM
Moderator
Rep:2140
Not sure what colour the wire will be as a few of us have seen it as different colours. But it will be the center wire on the 7 pin connector for sure.
Old 06-25-2013, 06:17 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I created this really ugly image when I installed my light bar. It goes along with a "how to" that I wrote up. Here is a link to it.
Hopefully this will make things a little bit easier for you. I would also highly recommend picking up an inexpensive multi-meter. These can save you a lot of time and aggravation when it comes to doing any sort of electrical mods. They can be had starting at about $20 for an analog one and the price goes up to pretty much what ever you're willing to spend for a digital.
good luck and keep us updated
Exco
Bill
Old 06-25-2013, 07:33 AM
Vehicle: .
Rep:4373
Reps for doing it yourself
Old 06-25-2013, 07:55 AM
jlc41's Avatar
jlc41 jlc41 is offline
Vehicle: 2013 Ram 1500 CC
Trim Level: Laramie Crew
Color: Western Brown two tone (Hershey Bar)
Rep:39
jlc41 is on a distinguished road
not to jack the thread, but what brand lite bar would you guys recommend???
tint, drop in bed liner, Avs window shades, Raptor bed rails, Dee Zee tail gate damper, Genos cabin air filter, Bak Roll-x cover, Weather tech mud flaps, Recon Xtrem tailgate bar, Moroso catch can, DoMore Slide Step, 5/16 Dual pin stripe, Reese lighted hitch cover, Master lock for hitch receiver, Truxedo bed lites, Hunter SS bull bar, Road Runner embroidered head rests, Plasticolor rear flaps with metal Ram logo, Mopar sill plates.
light bar lights
