Old 06-25-2013, 02:20 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Default CST Front 3" spacer leveling kit
Hey guys. Link to product below. I have contacted the company and waiting to hear back from them about this kit and re- alignment after installation. Have never seen anyone running a 3" leveling kit and was wondering if anyone here has this kit and was able to get alignment back in spec.
http://www.socalsupertrucks.com/2002...x#.UckmrmS9Kc0
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 06-27-2013, 09:20 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
3" is pushin it brah. Your suspension geometry is going to hate you.
If you want to get close to 3", get bilsteins and set them at 2.8"
2-2.5" is the most people usually go when leveling.
Old 06-27-2013, 01:39 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
If he's thinking about using a CST 3" leveling kit I'm assuming he's 2wd. So Bilsteins aren't going to work for him...
On a 2wd a 3" kit should work good. OP, you shouldn't have a problem getting your alignment back into specs with that kit. Provided you go to an alignment shop that actually knows what they're doing.
Old 06-27-2013, 01:44 PM
Rep:1900
that's my fault.. The CST didn't register.
brandonjansen strikes again...
bom bom bom
Old 06-27-2013, 05:19 PM
012RAMbo's Avatar
Rep:264
^^ haha. Yea I am 2wd, rep for the company got back with me and said they do a lot of the 3" kit with no issues at all. I did more research on them though, and they are made of urethane not steel like I thought. I was also wondering since this is a coil spacer and not a typical top of the strut spacer, do you guys think I would need taller shocks? The kit doesn't say they are needed, and the rep never mentioned anything about it either.
Old 06-27-2013, 05:23 PM
Rep:2026
If the kit doesn't mention needing taller shocks and the rep didn't either then I don't see it being an issue.... If you end up having a problem down the road you can always replace the shocks then.
Old 06-29-2013, 04:36 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
I've always heard 3" front spacer IS NOT good for your truck
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 06-30-2013, 05:50 PM
Rep:2026
Again, that's for a 4wd truck. The OP has a 2wd.
