Old 06-25-2013, 11:50 AM
baloo baloo is offline
Vehicle: 2012 Ram
Trim Level: sport
baloo is on a distinguished road
Default seat belt warning and chime then drivers airbag light
ok peeps, been loving my ram since i got it but have justv recently come acres an issue. from the moment i get in and start my truck the seatbelt light comes on, even when i put my belt on it stays on. once i start driving the evic flashes its warning and the chime starts going off all while the belt is buckled. then it stops and the drivers airbag light comes on for a bit then the seat belt light comes back on as well as the rest of the warnings an such!! cant get it in to the stealer till tomorrow but i leave for work then too. any ideas to what it is or can try?
Old 06-25-2013, 12:07 PM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2939
Check the connection under your seat. It may have come apart.
Old 06-29-2013, 10:09 PM
Vehicle: 2012 Ram
Trim Level: sport
checked that and it made no difference, was still connected so i disconnected and reconnected just to make sure
Old 07-02-2013, 01:52 PM
Rep:2939
Then, for some reason, the sensor isn't sensing that you have clicked your belt. Perhaps a broken wire within the harness. Perhaps a faulty sensor. It's a pretty simple setup, so it can't be too difficult to track down.
Old 11-09-2014, 07:43 PM
VINCENTR VINCENTR is offline
Vehicle: 2002 Dodge Ram 3500
Color: red
VINCENTR is on a distinguished road
Im having a similar problem. I turn the key to the on position the seat belt chime bell chimes 3 times when the seatbelt is latched. Crank up the vehicle and the seat belt light stays on, while driving I unlatch the seat belt no chime sounds. The seat belt light will not go off.
