Old 06-25-2013, 03:47 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
Default chance of rubbing +0 vs -12
Im pretty sure i know the answer to this as the more you push the wheel out, the more chance it has to rub.
nonetheless, not sure whether to go with a 0 offset wheel or a -12 offset. I like the stance of the -12 and how it sticks out. does anyone have any pics of an aftermarket 0 offset so i can see what kind of stance it has/how far it sticks out.
thanks!
Old 06-25-2013, 03:50 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
How far it sticks out and the chance of rubbing depends on the tire size you plan to run too. You didn't provide any information regarding tires so it's pretty much impossible to answer your question....
Old 06-25-2013, 07:34 PM
macc08's Avatar
Rep:722
my bad.
tires are gonna be 35x12.5's on either 17s or 18s. havent finalized my decision there.
Old 06-25-2013, 07:45 PM
Rep:2036
Okay... Well you are correct then. With a -12 you are going to be pushing it as far as rubbing goes. I did rub slightly when I first put my wheels and tires on. Fixed it up fairly easy though. There's tons of details and pictures of my truck including info on how I fixed the rubbing issue in my wheel and tire thread linked in my signature below. That will give you a really good idea of what you're looking at. A 0 offset would be tucked in 0.5" further than what mine are. Again, all those measurements are on my wheel/tire thread.
Old 06-25-2013, 08:19 PM
macc08's Avatar
Rep:722
i see the rubbing area at the back of the well there. i have a feeling that a change in offset wont affect the rubbing back there, looks like it will still rub. did you have any problems with rubbing in the front of the wheel well where the plastic part of the bumper came down?
Old 06-26-2013, 02:00 AM
Rep:2036
If I had a 0 offset rim I wouldn't have had any rubbing issues on the back. Guaranteed. The tire would be that much further back so at that point it would clear the inner fender no problem.
Haven't had any issues on the front. There's tons of clearance up there.
