Shifting problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-25-2013, 04:00 PM
dodgeram1999 dodgeram1999 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Laramie SLT
Color: Purple
dodgeram1999 is on a distinguished road
Default Shifting problems
I recently bought a 1999 dodge ram with the 5.9 and the 46re transmission. It has a shifting problem that i knew about before i bought it.
The problem is shifting out of 1st and 2nd gear. It starts happening once the fluid is warm and thin. When i leave from a stop it wont shift out of first until it reaches about 3500 or more rpms and the same for second but around 3200 rpms and sometimes it wont shift out of second. The previous owner brought it to a shop and the took the pan off and took the filter apart and they said they found metal shavings and clutch material in the filter. My dad told me that metal shavings is common but clutch material isnt. The shop said that the problem was the pump inside the tranny and it needed to be rebuilt. When it doesnt shift out of 2nd i have to shift into neutral then back into drive for it to shift. If anybody knows a way to fix it without rebuilding it please let me know. Thanks
Old 06-26-2013, 05:42 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
I don't believe at all that it could be the pump, the mechanic that checked it sounds like a quack. I did have a problem very similar to yours, and it happened to be the transmission speed sensor. The part is cheap and easy to replace, it's on the drivers side of the tranny.
I would just replace that as a precautionary measure.
Old 06-26-2013, 11:16 PM
Color: Purple
The more i look into the problem there seems to be more than one problem that causes it. I was looking at older threads and somebody said the adjusted the kickdown cable and that fixed it and i watched a video on youtube and they replaced the governor pressure solenoid and the control solenoid and it started shifting how it was supposed it. I may try adjusting the kickdown cable first to see what happens
Old 07-02-2013, 08:09 AM
Nck's Avatar
Nck Nck is offline
Rep:74
go for it man. Just try everything one by one, and hopefully you will find the culprit.
