Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2012 Dodge Ram Forum
Old 06-25-2013, 05:20 PM
punisher69's Avatar
punisher69 punisher69 is offline
Vehicle: 2012 Ram
Trim Level: slt crewcab 4x4
punisher69 is on a distinguished road
Default loose rubber roof trim piece
Washing the truck the other day,i noticed the rubber trim piece on the roof was loose on the drivers side about a foot from the rear.It feels like about 6" of it can move around like it is not fastened down anymore.Is this somehow glued down or snapped in? Does this trim piece cover the roof weld seam? Has anyone else noticed or encountered this problem and would you bring it in for service? Also I wonder how long this has been like this and if rust could be starting under there from the water I'm sure must be getting under there.
Old 06-25-2013, 05:28 PM
GrayhemiST GrayhemiST is offline
Vehicle: 2012 Ram Hemi Regular Cab
Color: Mineral Gray
Rep:277
GrayhemiST is a jewel in the roughGrayhemiST is a jewel in the roughGrayhemiST is a jewel in the rough
My strip came loose and he dealer replaced it.....there is a special adhesive attached to the bottom of the strip
Old 06-25-2013, 05:38 PM
Rep:2797
my '09 Ram roof strip started coming loose after almost 4 years
dealer fixed it & also replaced the 3rd brake light bulb
i am more worried about the left tail light bulb fixture
replaced the bulb in there twice
the fixture has a burnt look
wiped the bulb off with alcohol both times, no finger print oil on the bulb
Old 06-25-2013, 08:40 PM
5hole 5hole is offline
Vehicle: 2012 dodge ram
Trim Level: express
Color: blue
Rep:31
5hole is on a distinguished road
Mine did the same on driver and passenger sides at the rear about 6 inches so I just put some epoxy type stuff on and no problem since. I inspected it and there appeared to be no harm done so I figured it was not worth wasting my time at the stealership.
Old 06-26-2013, 09:17 AM
Buzzard's Avatar
Buzzard Buzzard is offline
Vehicle: 2012 RAM 1500 EXPRESS
Trim Level: EXPRESS
Color: True Blue Pearl
Rep:20
Buzzard is on a distinguished road
That happened on my '08 too. I used epoxy. Mine came loose where it bends down the back.
Old 06-27-2013, 03:29 PM
Kelevra's Avatar
Kelevra Kelevra is offline
Vehicle: 2012 Dodge Ram
Rep:91
Kelevra will become famous soon enough
Ditto. My pass. side strip popped up at the back of the cab. took'er in and replaced under warranty. No issues.
