Old 06-26-2013, 12:27 AM
Black Diamond 357's Avatar
Black Diamond 357 Black Diamond 357 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Black Diamond
Rep:25
Black Diamond 357 is on a distinguished road
Default Update On Leaking 3rd brake light
So I finally get a chance drop off my truck. After they found out where it was leaking from they put some kind of sealant on the light and put a ticket in to replace my headliner. I asked the service manager is the stuff they sealed my light with a sealant that I willnt be able to change my light. They looked at me very puzzled! I am asking you because if that's the case that is real stupid! She told me I have no idea but I will call you tomorrow when I have an answer. Now I know I am no car mechanic but I do work on airplanes. So if you are the boss or whatever don't you need to have a clue what kind of maintenance that is being done or be some what familiar! FML
Old 06-26-2013, 06:39 AM
Retxpres's Avatar
Retxpres Retxpres is offline
Vehicle: 2012 Dodge Ram Sport
Retxpres is on a distinguished road
Very common problem. I have had three Rams over the years. 2003, 2006 and now 2012. 2006 leaked through the top brake light. Seal and forget. I never had to replace those bulbs ever...
2012 Dodge Ram Sport...
Old 06-26-2013, 08:30 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
snusrak here on the forum wrote a how-to fix the leak yourself without the "bandaid" solution the dealer uses.
What's weird is the leaking brake light is prevalent on all makes of trucks. my 1998 f-150 did it. And I've heard many reports of other trucks, random makes and years that do it. Why they haven't solved the issue? beats me
Old 06-26-2013, 08:36 PM
Rep:25
Well, I they told me what they did and they got the ok from ram to replace my headliner just waiting on the part to come in
Old 06-26-2013, 10:11 PM
tjones524 tjones524 is offline
Vehicle: 2012 Ram Express Quad Cab 4x4
tjones524 is on a distinguished road
Mine wasnt leaking, but I took it off and put a good sized bead of silicone around the whole gasket, it's pretty much sealed up fully now.
I changed the bulbs when I did this, but it'll come off if I need it too, it's just silicone, I can rub it off with a finger and re-apply.
You can always just install a new thicker gasket and remove the old one as well, home depot is your friend!
Old 06-27-2013, 07:58 AM
Rep:25
Thanks for all of the info. I will more than likely redo it myself to my satisfication
Old 06-27-2013, 04:27 PM
whiteknight312 whiteknight312 is offline
Vehicle: 2012 dodge Ram Bighorn
Trim Level: big horn 4x4
whiteknight312 is on a distinguished road
you guys got me nervous! im ulling mine off and using Silicone gasket maker to seal them. I bought LED tails for my previous Nissan and they leaked. they never used any silicone around the lens and plastic surround. I made sure the forum people knew about these aftermarket lights. I always seal them. Now, I guess you have to seal the factory!!!!
thanks for heads up on this.
Chris
Old 06-27-2013, 04:47 PM
Rep:2705
the 3rd brake light bulbs do burn out
I have had mine replaced, it was burned out
Old 06-28-2013, 01:00 AM
Ramzaq Ramzaq is online now
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:251
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
Try this approach.
I highly suggest just doing this, it will be a better fix than the dealer will likely provide. Cost ~$10 and 15 minutes.
http://ramforumz.com/showthread.php?...ght=brake+leak
Old 06-28-2013, 08:53 AM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
This is what I don't understand. Why haven't they redesigned the 3rd brake light recess. It should be like a "pocket" behind the light, totally divorced from the cabin's interior. With nothing but a foam gasket as a barrier from the elements it's pretty much guaranteed to leak eventually. Think this might be one of those intentional engineering "oops", designed for the majority to fail post-warranty so the dealer can make a quick buck off the unwitting consumer.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
