ZDOG
Old 06-25-2013, 11:40 PM
Royale's Avatar
Royale Royale is offline
Vehicle: 2012 Ram
Rep:20
Royale is on a distinguished road
Default Awesome Tire Size Calculator
For those of you forumers who have troubles figuring out what size tire, wheel, or both you'll need or want on your truck. Here is an awesome tire and wheel calculator for you guys.
You can put in your current tire and wheel size then compare it to the tires and wheels you are wanting. It gives you the diameter, width, circumference, sidewall height in millimeters and inches as well as revolutions per mile/kilometer. The site also give you the speedometer reading difference from stock to larger/smaller overall size.
This has DEFINITELY helped me out.
Let me know what you guys think.
You're welcome in advance.
http://www.tacomaworld.com/forum/tir...5r22-305-35r22
Old 06-25-2013, 11:46 PM
Grubrunner's Avatar
Rep:3883
Yeah, I've seen one or two similar links posted on these boards before and they do come in handy.
Good find.
Grub out!
Old 06-26-2013, 02:57 PM
phobos512's Avatar
phobos512 phobos512 is offline
Vehicle: 2013 Ram 2500 4x4 CCSB CTD
Color: Maximum Steel
Rep:6
phobos512 is an unknown quantity at this point
1010tires and Miata.net both have comparable calculators. The one 1010 has is nice because it doesn't rely on flash, and you can compare multiple tire sizes simultaneously in a spreadsheet format.
Be careful though with the Tacoma one as there's some info on there that's not valid for any other vehicle - the gearing/RPM info. It's all setup for their vehicle and can't be changed (while it has a list of final drives that has to use information on the transmission gearing which will vary).
Matt || 2013 2500 Laramie || CCSB 4x4 CTD || Maximum Steel || Nitto Terra Grapplers 305/70-17s
Old 07-03-2013, 12:01 PM
GAltima GAltima is offline
Vehicle: 2010 Ram 1500
Rep:40
GAltima is on a distinguished road
Just stumbled across this myself. Awesome for helping me decide which size tires to go with.
Old 07-03-2013, 12:14 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Dont be surprised if it gets pulled for advertising/posting another forum.
Old 07-03-2013, 12:15 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2015 Ram Bighorn
Trim Level: Bighorn
Rep:108
Graygoose will become famous soon enoughGraygoose will become famous soon enough
Nice find...saved for future reference.
2015 Crew Cab Bighorn
