Old 06-26-2013, 05:52 AM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
Default 6.1L intake manifold upgrade on 5.7
has any body done this upgrade? I would llike to upgrade the 5.7L intake manifold to the 6.1L along with the fuel rails. Is this even possible? what modifications would need to be done? would it even be worth it?
Old 06-26-2013, 08:25 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
if you want to dress up the bay then sure but to expect performance per your mods + cost + install involvement then it would be better to keep the 5.7 manifold.
Positive thing going for you is the 6.1 manifold intake ports will match up to the eagle heads design.
Old 06-26-2013, 10:10 AM
I push the skinny pedal
Rep:3277
It's a direct bolt on, just clock the throttle body 90 degrees. As mentioned above the performance gains aren't that impressive because the '09 truck intake manifold has the active runners so it maintains the low rpm power and still flows nicely in the upper rpm. Unless you're planning boost you won't be able to really take advantage of the 6.1L manifold without losing some of your bottom end.
Kurtis
Old 07-01-2013, 10:49 PM
Ramfd's Avatar
Rep:150
cool thanks guys
Old 07-02-2013, 12:02 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I've had mine in the garage for a while now, waiting on some kind of boost or nitrous.
Old 07-02-2013, 01:35 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
To you and Ramfd...I think it would be worth the swap, better port match, and it's not made of plastic. Like CdRam says or maybe you may be able to eliminate your cai box all together by scrapping your fan and shroud and leave the tb on the 6.1 as is? And use a 90 degree tube facing out to the right front radiator...just a thought?
Old 07-02-2013, 11:51 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
You got to get the short runner valve written out of your tune... And you need to either clearance the throttle body or the intake manifold so the throttle body will bolt up to the manifold. Its not as easy as just clocking the throttle body 90 degrees cuz the lip of the cover on the throttle body touches enough to not let you bolt it up the only way possible for our motors... So your gonna need and aluminum bit and a hefty drill so you can grind a small area where it touches...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-02-2013, 12:06 PM
916Timmy's Avatar
Rep:1443
I was going to put a pod filter right on the TB opening and have a nitrous plate between the manifold and the TB so I wouldn't have to grind anything or rotate the TB 90 degrees.
Old 07-02-2013, 12:10 PM
RamTex's Avatar
Color: Stone White
Rep:366
Alternator is in the way of the TB you have to turn it so that the TB cover is facing up...
Old 07-02-2013, 12:17 PM
RamTex's Avatar
Color: Stone White
Rep:366
And then comes the question of how are you going to run the fuel rails because our stock line wont reach that far lol... I suggest getting Arrington Fuel rails and doing all the plumbing with jegs stainless hose and getting the fittings like i did and replacing the stock feed line from the gas tank completly.
