Old 07-02-2013, 11:27 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You can build an extension with Mustang fittings to go across to the other side of the manifold. I am with you on replacing the whole line from the tank though.
Old 07-02-2013, 11:35 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
If you get a 6.1 intake from a salvage vehicle can you use the fuel rails that come with it for your truck? Is this you in these pics RamTex? Engine bay looks sweet, color and cai tube is awesome...good job.
Old 07-02-2013, 12:40 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Yeh this is mine i need to post an updated version with the new arrington fuel rails and stainless crossover line connecting the rails it looks so much better than this setup.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-03-2013, 10:36 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
sweet, good info ramtex, thanks
Old 07-04-2013, 09:49 PM
I push the skinny pedal
Rep:3277
Yes, you can use the stock 6.1L fuel rails, you'll just need an extension for the fuel line, the Zex fuel adapter will work for this, and it gives you an NPT port to install a fuel pressure sensor.
Originally Posted by RamTex View Post
And then comes the question of how are you going to run the fuel rails because our stock line wont reach that far lol... I suggest getting Arrington Fuel rails and doing all the plumbing with jegs stainless hose and getting the fittings like i did and replacing the stock feed line from the gas tank completly.
I third the option of running a complete fuel system. If you're doing this for boost then you should also add a fuel pressure regulator with a return line and 1:1 boost reference port.
Kurtis
Old 07-08-2013, 10:34 AM
RamTex's Avatar
Color: Stone White
Rep:366
Just from experiance i used the zex line extention and it leaked a tiny bit right at were it connected to the 6.1 fuel rail others might have not had this happen but mine did leak. So if you plan on doing this yes the zex line will work but i wouldnt plan on having it on there for long mainly because it looks hidious and it might leak a tiny bit which isnt cool at all...
