Old 06-26-2013, 12:52 PM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Trim Level: Laramie Longhorn
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
From the manual;
Rain Sensing Wipers — If Equipped
This feature senses moisture on the windshield and
automatically activates the wipers for the driver. The
feature is especially useful for road splash or overspray
from the windshield washers of the vehicle ahead. Rotate
the end of the multifunction lever to one of five settings
to activate this feature.
The sensitivity of the system can be adjusted with the
multifunction lever. Wiper delay position 1 is the least
sensitive, and wiper delay position 5 is the most sensitive. Setting 3 should be used for normal rain conditions.Settings 1 and 2 can be used if the driver desires lesswiper sensitivity. Setting 5 can be used if the driverdesires more sensitivity. Place the wiper switch in theOFF position when not using the system.NOTE:• The Rain Sensing feature will not operate when thewiper switch is in the low or high-speed position.
Looks like it needs to be on in order to enable.....
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 06-26-2013, 12:55 PM
rkuhl84's Avatar
rkuhl84 rkuhl84 is offline
Vehicle: 2013 Ram 1500 Sport QC
Rep:88
rkuhl84 will become famous soon enough
My previous 2010 Volkswagen CC had automatic wipers and it was a very nice feature that I wish my Ram had. I thought it was ridiculous to begin with but it is nice when you go in and out rain or the rain intensity varies. It would wipe the windshield almost instantly after meeting a semi that doused the windshield with water as well.
My VW had three levels of sensitivity which I'm guessing the Ram's have something similar. You have to mess with it a bit to figure out where you need to be but works pretty well once you get it honed in. The VW version seemed to adjust to your speed as well.
Old 06-26-2013, 01:00 PM
nikeman nikeman is offline
Rep:91
So I have to keep the wipers on all the time? It
Can't find anything about the feature in the ram toolbox app. Maybe I should bust open the DVD manual.
Old 06-26-2013, 01:10 PM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
This ^^^ I've heard the settings on the multi-function lever adjust the sensitivity of the wipers. I'm assuming if that's turned off completely the auto wipers will not work.
That is how they function on my truck.
Originally Posted by ptesmoke View Post
but arent they supposed to be "automatic"??
They are, you enable the feature in the EVIC and then set the sensitive using the stalk selector switch. Set it and forget it.
Look in your owners' manual, begins on page 172.
Old 06-26-2013, 01:27 PM
ejb426 ejb426 is offline
Vehicle: 2013 Ram 1500 CC 5' 7" bed
Color: Copperhead Pearl
Rep:20
ejb426 is on a distinguished road
Originally Posted by Clarkgriswald View Post
How are the auto high beams supposed to work?
With the feature enabled in the radio, push the turn signal lever all the way forward like you are turning the brights on. A message in the EVIC will display that the auto high beams are active.
Old 06-26-2013, 01:37 PM
Rep:91
So I guess they don't adjust the speed automatically if it goes from a drizzle to a downpour? You still have to adjust the speed as needed correct? I had higher expectations of this feature I guess but its still cool.
Old 06-26-2013, 01:41 PM
Rep:20
No it changes depending on sensitivity. Another term for sensitivity in this case would be density. Some people don't want a single drop of rain on the windshield. I was using them last night and it seemed like when the light hit the windshield, they started working faster. I prefer level one and it was working great for me.
Old 06-29-2013, 01:04 AM
RedWingFan's Avatar
RedWingFan RedWingFan is offline
Vehicle: 2013 Sport Hemi RamBox ordered
Trim Level: 2013 Sport
Color: Dark Cherry
RedWingFan is on a distinguished road
I had mine on level 1 yesterday and if barely drizzling it would intermittent wipe like you would expect. When the rain got heavier, the interval increased and even heavier, became a steady wipe for 2 or 3 cycles.
Old 06-29-2013, 02:15 PM
FeedMetal's Avatar
FeedMetal FeedMetal is offline
Color: Maximum Steel Metallic
Rep:83
FeedMetal will become famous soon enough
i tested this in my 2013 as well. drove in a storm even. you have to turn the wiper setting on one click and it will take over from there. kinda lame but good i guess this way you dont have to go into settings everytime u want to go to the carwash or something
'13 Sport Crew Cab / Hemi / 6-Speed / 3.55 / Anti-Spin - aFe Stage II CAI - MF 14" Muffler - BP 87mm TB - BP Catch Can
Old 06-29-2013, 10:17 PM
sharker sharker is offline
Vehicle: 2013 ram sport
Trim Level: sport
sharker is on a distinguished road
The only problem i have is when it's raining just a little, my wipers will go slow for a minute then super fast for 10 seconds and back to slow. It was raining the same intensity all the time. This was set at the first notch. Anybody else have this problem.
