Place your Ad Here!
Old 01-13-2014, 05:47 PM
JasonGriff's Avatar
JasonGriff JasonGriff is offline
Vehicle: 2009 Dodge Ram TRX4
Trim Level: TRX4
Color: Blue and gray
JasonGriff is on a distinguished road
Ram357
do you have any rake on yours? The pic in the snow looks like it is very close to being level.
2009 TRX4 ^ 4" BDS lift^ 35x12.50r20 kumho venture mt ^ 20x10 ^ drop in K&N ^ 3.92's^ 5% TInt
Old 01-13-2014, 05:48 PM
RAM357's Avatar
RAM357 RAM357 is offline
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Can you check to see if the previous owner put a coil spacer in the rear? Maybe he carried a diesel tank (for bush equipment) or sleds etc requiring more lift in the rear.
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau* Iron Bull Fr. bumper with custom Line-X coating* Lumens HID low beams
Old 01-13-2014, 05:52 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Originally Posted by RAM357 View Post
My BDS 6" lift came with an option of 5" rear coils if you wanted instead of 3" coils. If I had gone with the 5" rear coils I would have had a 2" rake roughly.
Did you opt for a longer rear coil by any chance?
Even with the coil overs adjusted? Are they cranked at the highest point?
sales@revelperformance.com
Old 01-13-2014, 05:57 PM
RAM357's Avatar
Rep:580
Originally Posted by JasonGriff View Post
Ram357
You're spot on! It is very very close to level. Every truck is a snowflake in terms of the amount of rake it come with. In my trucks case I guess I got a little lucky. In the instructions on the BDS site they tell you to measure your rake (measuring from mid axle to lower flare, front & back - subtracting the front measurement from the back measurement, giving you the rake. e.g.: 2.5" etc) Then they state if you rake is below a certain amount (which I can't recall) then go with the 5" coil, BUT if you have a LOT of rake already then go with the 3" rear coils, BECAUSE if you already have a ton of rake you absolutely do NOT want to add to it by installing a LONG rear coil.
Ok, HOLD it .. I just familiarized myself again with the BDS 4" lift and they only give you rear spacers for the lift; not coils. I was thinking 6" lift, sorry.
From BDS writeup:
Due to the OE ride height variances, BDS offers three rear lift options to get your desired stance: 2″ coil spacers, 3″ Pro-Ride coil springs, or 5″ Pro-Ride coil springs.
And their lift:
Hmmm, can you just remove the rear 2" spacer??
Old 01-13-2014, 06:06 PM
RAM357's Avatar
Rep:580
Good distinction. I am referring to how things would pan out when the coil-overs are installed AS shipped.
It's interesting that the BDS literature I got states the coil overs are adjustable from 4" to 6". I cannot see where it suggests increasing their preload for more than 6" lift. To my thinking, Fox determined the perfect coil, oil weight, and valving for our application so why mess with that?
Frankly I wouldn't want to. Fox set this up perfectly for the 1500. Why mess with that? Instead I would install the approx. 2" spacer that you can optionally install on top the coil-over. Perhaps that and the 5" coils would net you 8" lift .. add 37's and you'd be at 10" total lift without body lift Nice...
Old 01-13-2014, 09:14 PM
Revel Performance
Rep:1804
And their lift:
Yes sir you can. You can opt for a 3" rear coil vs the 2" spacer
Old 01-13-2014, 09:15 PM
Revel Performance
Rep:1804
So you just had the shop install the coilover as is without any adjustment?
Curious... That's all
Old 01-13-2014, 09:27 PM
RAM357's Avatar
Rep:580
Good point! Well then perhaps the previous owner opted for the 5" coil
Yes .. no adjustment, at least to my knowledge.
It's nice that the BDS lifts have some flexibility in them, either in the coil-over, or the coil/spacer selection.
Old 01-13-2014, 09:32 PM
Selcher's Avatar
Selcher Selcher is offline
Vehicle: 2015 Ram Sport
Trim Level: Black Ram Sport 1500
Rep:16
Selcher is on a distinguished road
This is interdasting stuff... I'm feeling like I'll go with the 5" rear coil because I actually enjoy some rake...
BDS 6" Coil Over Lift | Fox 2.5 Remote Reservoir Shocks & Eibach Coils ~ Fox 2.0 & 5" rear | RPB 94R's 20x10 -25mm offset | Toyo AT2 Xtreme 35x12.5x20 | Bushwacker Pocket Flares | MBRP Catback & Black Tips | S&B CAI | DiabloSport ~ HemiFever 91 | Mopar Bed Rug | Extang Trifecta | AMP Research Steps
Old 01-13-2014, 09:38 PM
RAM357's Avatar
Rep:580
Another guy near me with a white RAM went with the identical lift, save rear coils. He went with the 5". I should call and see if he put the coil-over spacer in up front. I was at the shop this afternoon and the truck looked pretty level.
Do you want me to inquire for you? If it's still there I could take measurements.
