Old 01-13-2014, 09:40 PM
Selcher's Avatar
Selcher Selcher is offline
Trim Level: Sport Club Cab 4x4
Selcher is on a distinguished road
Yes, indeed... I think this thread requires that information....
MBRP Pro Series Cat Back Exhaust
Superchips Flashpaq 3865
Old 01-13-2014, 10:07 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Ok, if it's there I'll see if I can measure it up. Maybe snap a photo. If not I can talk to the installer to see if they installed the spacer up front above the coil-over.
Cheers
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-15-2014, 10:42 AM
cdyogletree's Avatar
cdyogletree cdyogletree is offline
Vehicle: 2012 Ram 1500
Rep:25
cdyogletree is on a distinguished road
Year/Model - Ram 1500 4x4
Lift Size - 6" BDS
Bilstein: Yes- 2.8"
Body Lift: NO
Tire Size - 35x12.50 20s
Wheel Size - 20x12
Pros/Cons - Pretty easy install, rides amazing with Billys and rear Fox 2.0s, and I think it looks pretty good
Any other suspension add-ons - Next upgrade is 2.5 coil-overs
[SIGPIC][/SIGPIC] '12 Ram 1500 lifted and stuff
Old 01-15-2014, 11:26 AM
sled92's Avatar
sled92 sled92 is offline
Vehicle: 2013 Ram 1500 QC 4X4
sled92 is on a distinguished road
Lift Size - 6" BDS
Bilstein: Yes- 2.8"
Body Lift: NO
Wheel Size - 20x12
Great looking truck cdyogletree! Anymore info on your tire and wheel set-up? Brands? Model? Offset?
Daystar 2-1/2" Level. Goodyear Duratrac 285/70/17. Weathertech floorliners. Weathertech mudflaps. S&B CAI. Diablo Intune DCX with Hemifever Tuning.
Old 01-15-2014, 11:43 AM
Rep:25
Thanks!! They are 20x12 Moto Metal 962's with -44 offset. They stick out of the body about 2"
Old 01-15-2014, 01:37 PM
Looks amazing man!
Lift Size - 6" BDS
Bilstein: Yes- 2.8"
Body Lift: NO
Wheel Size - 20x12
Old 01-16-2014, 01:53 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
Originally Posted by Selcher View Post
This is interdasting stuff... I'm feeling like I'll go with the 5" rear coil because I actually enjoy some rake...
Originally Posted by RAM357 View Post
Another guy near me with a white RAM went with the identical lift, save rear coils. He went with the 5". I should call and see if he put the coil-over spacer in up front. I was at the shop this afternoon and the truck looked pretty level.
Do you want me to inquire for you? If it's still there I could take measurements.
I returned to the shop and the truck was on the alignment rack. I measured from the centre of hub to under flare and got 26.5" front, and 27" in rear with the 5" coil, BUT it had the old tires/wheels in the bed of the truck so it's not a fair measurement.
What I can tell you is what I saw, and what the comments of the shop boss were in regards to the 5" rear coil - 'I sat in it and on yours (mine) you can definitely tell it is level .. your hood just appears to look that way, BUT on this other truck I could definitely sense the rake. The hood looks like its sloping way down from inside, and there is most definitely a big rake when looking at in from the side.'
Hope that helps a tiny bit..
Old 01-16-2014, 03:13 AM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
Regardless of what wheel and tire combo is on the truck, the measurement from the center of the hub to the bottom of the flare would be the same.
Old 01-16-2014, 03:35 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
Unhuh .. I never mentioned his wheel size or the fact that he has 37's now.
I isolated my comments to the 5" rear coils and the hub to flare measurement being 27"
His OLD tires & wheels were in the 'box' of his truck, weighing down the rear making my measurement not entirely accurate.
I just want to be clear .. or were you making a general statement above?
The reason I measure from mid hub to flare bottom is so guys can see the pure suspension input, and then just add 50% of their chosen tire diameter (radius) to appreciate height increases.
Old 01-16-2014, 09:24 AM
This is not surprising to me.
Many that we sell BDS kits to with 5" rear coil max their Bilsteins and still have some slight rake ranging between 0.75"-1.25" depending on previous rake.
This is partly due to the need to remove the 5/8" preload spacer leaving you with the 4.5" strut spacer.
And the lower drop brackets included.
I don't see this being any different on the kit with the coilover
My truck as an example is 45.5" front and 46.5" rear
I have 6" RCX, Bilsteins set at 1.4 and a 1" rear coil spacer on 37's
