Old 08-14-2014, 07:09 PM
asavet18's Avatar
asavet18 asavet18 is offline
Vehicle: 2014 Ram 3500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:19
asavet18 is on a distinguished road
Realized I haven't posted up my BDS setup in this thread. So here it is...
8" BDS long arm lift with Fox 2.0 shocks
Fox 2.0 dual steering stabilizer
Hell Bent Steel steering box brace
2" Motorsport Tech BORA wheel spacers
37x13.5 Toyo MT's on stock rims
For the full writeup, more information, and more pictures see post 557-560 on my build thread HERE
Damn that's a nice setup .... If you don't mind me asking how much did it it cost?
Old 08-16-2014, 12:30 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Thanks man!
I got a good deal on the lift kit with my sponsorship through Bully's Performance. But the MSRP on the kit set up the way I have it is about $2900. If you're interested in getting it I can get you all the details and part numbers for the steering stabilizer setup and you can contact Eric at Bully's for pricing with the forum discount.
I ended up getting a good deal on the 2" BORA wheel spacers as well but the MSRP on them is $480.
The best deal I could find on the tires was at OK Tire in Abbotsford. Taxes in I think I paid around $2100 for them.
So with by the time you get the lift and spacers into Canada you're look at around $5900 for this setup. But like I said that's a rough ball park based on MSRP values. You can probably get a bit of money off that lift by contacting Bully's.
Old 08-16-2014, 02:35 AM
asavet18's Avatar
Rep:19
Sweet thanks for the info... did you do the install yourself or did you get a shop to do it? How much was the install?
Old 08-17-2014, 01:11 AM
Rep:2036
Did the install myself. Definitely wasn't an easy task though and I wouldn't recommend it if you aren't a pretty decent mechanic. Welders, cut off wheels, and die grinders were involved.... You can read the full install write up on post 557-559 of my build thread linked in my signature.
Overall I probably had about 20-22 hours into the install. Now a shop should be able to do it quicker than that but I'd guess you're looking at +/- $1400 to get it done depending on what the shop rate is.
Old 08-18-2014, 04:47 PM
asavet18's Avatar
Rep:19
Yeah the most difficult things I've ever done is swap tranny's, brake jobs, change clutches you know the normal stuff but never any welding ... guess I'll have to budget for shop fees .... thanks for the info
Old 10-23-2014, 01:54 PM
Kuzikan2010 Kuzikan2010 is offline
Vehicle: 2010 Dodge Ram SLT
Rep:128
Kuzikan2010 will become famous soon enoughKuzikan2010 will become famous soon enough
Here is mine...
2010 Ram 1500 SLT 4x4
6" BDS w/ 3" PA body lift
37x13.5 Toyo's w/ 22x12 Fuel Mavericks
I purchased Bilstein's but am currently deployed so they will have to wait until I return.
If my info is right, i'll have to take out the 5/8" preload spacer in order to install the Bilstein's, is that correct? Also w/ them installed and the spacer taken out, am I looking at about 1-1.5" of lift? Thanks for the help!
2010 Dodge Ram 1500 SLT Quad Cab 4x4
Old 10-23-2014, 02:02 PM
Rep:1797
Originally Posted by Kuzikan2010 View Post
Here is mine...
BADASS ^^^^^
Old 10-23-2014, 02:51 PM
Rep:2036
Here is mine...
Nice wheel and tire setup! Definitely love the look if 22x12's with 37's.
Correct, you will not install the 5/8" preload spacer on the Bilsteins when you assemble them. You'll want to set the Bilsteins at 2.1" if you want your truck to be level. 1.4" if you want a slight amount of rake.
Old 10-23-2014, 04:04 PM
Rep:128
Thanks! and thanks for the info! If I install them at 2.8, is that going to mess with anything? Will the cv angles be too steep? I'd like the front to sit just a little higher, but if it messes w/ the angle to much, level will do!
Old 10-23-2014, 04:20 PM
Rep:1797
Its kind of one more notch up from what Brandon said.
2.1 for rake and 2.8 for level.
If your rake is over 3.25, you still won't be leveled at 2.8
But BDS has amazing drop brackets that even at 2.8, its better than guys with RCX at 1.4
Go figure.....
