Trans lines Question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 09-17-2013, 01:31 PM
willy1 willy1 is offline
Vehicle: 95 Dodge Ram
Trim Level: basic
Color: red
willy1 is on a distinguished road
Default Trans lines Question
I have a 1500 2nd gen.. needs translines replaced there leaking badly.. were can i get them besides a dealer and what do i need.. im not the best at simple things.. but i can replace no problem.. just not sure, i looked at napa, autozone, etc.. they seem to have a top line but not the bottom,, so idk what i should do.. aftermarket is fine..
Old 09-18-2013, 08:25 AM
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Where are they leaking? Just at one spot, or multiple places?
If it's at just one spot in the middle of the line, you can cut out the bad spot and install a union (compression fitting) there. Or for a longer bad spot, splice in a new piece of tubing with two unions.
If you have to replace the entire line, you might try a shop that makes hydraulic hoses. If you match the fittings on each end, they could make you up a rubber hydraulic hose to replace the metal line. Just route it carefully (away from exhaust system and moving parts) and tie strap it in place. Make sure they use a hydraulic line that will handle HOT oil without failing.
