Old 06-26-2013, 07:44 PM
hriczko806's Avatar
hriczko806 hriczko806 is offline
Vehicle: 2004 Ram Quad Cab
Rep:91
hriczko806 will become famous soon enough
Default upgraded tires, what tire pressure?
I went from the stock 265/70/17 and upgraded to 285/70/17. The stock tire pressure is 35PSI I believe. What should I put in the 285's? Should I have a little bit more pressure?
Old 06-26-2013, 08:09 PM
Grubrunner's Avatar
Rep:3883
Leave it the same.
Grub out!
Old 06-26-2013, 08:44 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Originally Posted by Grubrunner View Post
Leave it the same.
This^
Keep it with the OE spec.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 06-26-2013, 09:29 PM
hriczko806's Avatar
Rep:91
Ok thanks, Ill leave it the same as the 265s
Old 06-26-2013, 09:42 PM
Grubrunner's Avatar
Rep:3883
Good call.
It's not a significant alteration in size to warrant any drastic PSI changes. Also, my suggestion was based on my assumption that you stuck with near or identical tread pattern [tire type] to OEM, as you didn't disclose anything other; correct?
HERE is a good read regarding your concerns and then some more.
Though, I'll say up front, I don't agree with all the content.
Good luck.
Grub out!
Old 06-26-2013, 09:47 PM
hriczko806's Avatar
Rep:91
That's correct, I stuck with a fairly similar tread pattern. It's an A/T tire but isn't overly aggressive. The tire is a Bridgestone dueler A/T revo 2.
I also read somewhere that the ideal tire size for any tire is 10% less than what the sidewall of the tire says. The author made some good points. I'll check out your link too. I appreciate it.
Old 06-27-2013, 08:00 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
Just for the record....tire PSI is not relative to the tire size. PSI is a measured value; meaning you have more volume of air, but pressure would remain constant.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 06-27-2013, 09:51 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:387
It is totally dependent on the load rating. You don't want to be running 35 psi in 80 psi rated tires.
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Goodyear Duratracs. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector. More AR's than you can shake an AK at.
Old 06-27-2013, 11:32 AM
latitud's Avatar
Rep:78
35 PSI is fine on a tire that has an 80 PSI rating if it is on a RAM 1500. The 80 PSI rating on the sidewall is the MAX inflated pressure to meet the MAX load rating printed in the sidewall. The lower the PSI the lower the allowable weight capacity.
