Old 06-26-2013, 11:46 PM
Darrenwood128 Darrenwood128 is offline
Vehicle: 1995 Dodge ram 1500 4x4 5.2L
Trim Level: Larime
Darrenwood128 is on a distinguished road
Default Not going into 4x4
Hey, my truck sometimes does not want to go into 4 wheel. I sprayed deep lube all over the linkage and that worked for a bit then tried it yesterday and it would only go in if you put it in slowly. Clunks very hard when it engages. Is my transfer case going or is there anything else to grease? Truck also makes a grinding noise on initial take off for a second and then goes away, 4 wheel or 2 wheel.
Old 06-27-2013, 12:54 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
free bump...............
Old 06-27-2013, 02:15 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
You can try adjusting the linkage rod a couple spins between the shifter and the linkage. It might have a little less tolerance since it's got some miles on it.
