Old 06-27-2013, 12:39 AM
Ninelrod Ninelrod is offline
Vehicle: 2010 dodge ram
Trim Level: Slt
Color: Brown
Ninelrod is on a distinguished road
Default 2010 ram 1500 2wd with 2" leveling kit "death wobble "
Iam having a major dilemma with my truck. I purchased my truck with a leveling kit already installed. Truck recently stated to wobble at highway speeds making uncomfortable to drive. All I know it's a steel spacer and still has factory shocks. I gotten the truck aligned at the dealer but no good. Someone please help!
Old 06-27-2013, 01:16 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I would check to make sure you don't have worn parts like ball joints, tie rods, etc.
Old 06-27-2013, 09:41 AM
Trim Level: Slt
Color: Brown
That's what I plan to do tomorrow. Iam going to take it to an alignment shop that I know does quality work.
Old 06-27-2013, 09:46 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
is it just a vibration/shudder...? or the actual "death wobble"
the death wobble is horribly violent. Have you seen videos of it??
Old 06-27-2013, 10:51 AM
Trim Level: Slt
Color: Brown
The truck vibrates and the steering wheel wobble a lot at 50 mph and up.
Old 06-27-2013, 05:23 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is online now
Vehicle: 2012 Ram 1500 CC
Rep:264
Did this just start? Have you made sure the tires are balanced correctly or you may have a bent rim? Never heard of a leveling kit doing that.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 06-27-2013, 05:51 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Number one, it isn't death wobble. Actual death wobble is only possible in solid axle front ends such as a 2500/3500. Your 1500 has IFS....
I would definitely be checking the front end parts such as the tie rod ends, ball joints, etc. That would be the first place. Verifying the alignment would be a good idea but a small misalignment shouldn't cause that kind of issue.
Wheels being out of balance would also cause a vibration and wobble. I would have those checked as well. Also, do you have stock or aftermarket wheels? If they're aftermarket and not hubcentric that would cause that issue as well.
