Old 06-27-2013, 03:11 AM
redline511's Avatar
redline511 redline511 is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: laramie
Color: red
redline511 is on a distinguished road
Default Heated seats
Hey guys got a question for ya. I have the two tone leather seats but no heaters . I was wondering if anyone has installed a universal heater kit in their truck or if it is possible. I have noticed that their are a lot of hog rings in the seat bottom so I do not know if the universal heater will work or will I have to buy a oem. Also on a different subject has anyone switched their side mirrors to the newer style with the heat and led with turning signal. Just wondering because I like the look and was hoping it would be a bolt on or light mod. Any info would be great help. Thanks Guys
Old 10-05-2013, 07:02 PM
Tet's Avatar
Tet Tet is offline
Vehicle: 2003 Dodge Ram
Trim Level: 1500 SLT
Color: Burgandy
Tet is on a distinguished road
Talking Heated Seats
Okay I want to revive this question because I see it's been a few months since you asked!
I am new here and I work at an automotive custom shop and we specialize in installing Katzkin Leather Interiors, Heated Seats, and Seat Coolers. We also install sunroofs, reverse cameras, and all sorts of other automotive accessories.
I install katzkin kits and seat heaters all day long and let me briefly show you how they work and how you properly cut them so you can still hog ring or Velcro your listings (depending on what your seats have) without damaging your heating pads.
Below is a picture showing the location of the main Positive Wire (+) and main Negative Wire (-). These pads are wired in parallel and each row of wires running horizontally are powered by the main positive and negative vertical wires on the sides. If you sever either of the main vertical wires nothing above the point you severed will work and anything below the severed point will still function.
So you place the pad on your cushion and you have a listing running horizontally and need to hog ring your cover to the cushion but the heating pad is in the way. You need to cut out a 'window' that doesn't sever either of your vertical main wires like below. this will still keep the horizontal wires that are above and below your 'window' operational. Also, you can cut as many windows as you need but the more you take away the less area you have to heat up.
There is really no reason to order the stock heating elements unless your just wanting to keep a stock look for your switches but either way the universal seat heaters work on any vehicles seats.
** One last thing I want to illustrate is sometimes you have seats that have vertical listings on your cushions. If you cut a vertical window you sever the connection from (+) to (-) the entire run of the window you cut out. So do not cut the heating pads like this below:
What you want to do is on your cushion where the listing is located you want to tuck the heating pad into the crevice where the listing is and apply glue on top of the heating pad in the crease. then spray your leather cover where the listing is located so the listing will be glued down into the crease and it will look like its still hog ringed down. **
If anyone has any further questions please feel free to ask!
Old 10-07-2013, 06:23 PM
Tet's Avatar
Tet Tet is offline
Color: Burgandy
Cool Revision on Previous Post
So today at work I was installing Katzkin Leather and Heated Seats on a 2014 Ford Escape SE, and wanted to take some real pictures instead of the ones before I edited in MSPaint.
As you can see in the above picture, this seat cushion has a horizontal listing that the heating pad will cover up and prevent you from being able to secure the cover with hog rings.
As you can see above I highlighted the main positive and negative wires that run vertically up the sides. Cut your window out with a razor blade to start then finish the window with scissors. You will want to cut extra on the top of the window so you can tuck into the crevice like below:
As you can see above the pad is now glued down and tucked into the crevice and the wire is fed down to the bottom through the + shaped cutout on the cushion.
Now you can see above I hog-ringed the listing on the new cover through the window onto the cushion and it's tucked into the crevice nice and snug.
Now the new Katzkin leather fits like the seat heater isn't even under it.
Hope this is easier to understand seeing it actually installed.
