pinion nut continued.. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-27-2013, 06:48 AM
muskybait muskybait is offline
Vehicle: 2010 1500 Dodge Ram
Color: Two tone Black/Silver
muskybait is on a distinguished road
Default pinion nut continued..
Hi Gang,
I received the 2nd follow-up letter on this recall a few days ago. I called Chrysler Canada to confirm the status of the parts for this fix. They are now available and are currently being shipped to the dealers and have been assigned dealer part numbers, etc..
I called dealer and they were completely oblivious to any of this. Had no idea the part existed, etc..after 20 minutes of checking online, etc they finally found the part and ordered them.
The warranty time estimated for the fix ranges from 30 mins to 6 hours depending on if the nut has been loose and to what extent damage to axle.
According to the letter I received the warranty work does require an inspection of the nut to determine if loose and to what extent. If not loose they are to install a retaining ring. If loose, rear axle reconditioned.
I find it incredible that the dealer would not be aware of the details on this recall. Do they not communicate at all with Chrylser Canada or US.
I received my first letter last fall. My dealer told me, nothing they could do until the part was released. Should they not have at least inspected the nut to determine if it was loose and service accordingly based on first recall?
Is my dealer servce department below standard here..I just get the feeling my guys dropped the ball on this.
Any comments appreciated.
Musky
Old 06-27-2013, 10:24 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
you raise a good question about what should be done, inspection" before they have the part, but it seems all dealers are treating this recall the same. "nothing they can do until the parts are available". so, no, your dealer is not below standard on this, but the bar hasn't been set to high on this recall.
Old 06-27-2013, 09:35 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
I've had two separate dealers rebuild my diff three times due to failure - and neither one of them was aware of the recall after NHTSA announced the investigation (because the recall was supposed to be out end of last year but chrysler delayed it), after the first letters arrived or now. The service managers at these two dealerships should go and decapitate themselves. Idiots. I mean any time I've mentioned this recall they look at me like I'm growing a cigar out of the back of my effing head.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2017 Dodge Durango GT
2012 Jeep Grand Cherokee Limited (SOLD)
