Old 12-22-2013, 04:20 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Ya mine is still leaking as well, I fixed it once with some gasket maker and that lasted about a month and then it started again, then i took it out coated the crap out of it with hot glue and well it started leaking right away when i put it back in, so its time for a whole new one i guess!
Old 02-09-2014, 02:29 PM
docsavage300 docsavage300 is offline
Trim Level: laramie
Color: austin tan pearl
docsavage300 is on a distinguished road
I had the same problem and thought the tank was leaking. After removing the tank and cleaning the entire outside and refilling it with the water and let it set for hours and no leak. After reinstalling the tank and refilling with water, two days later it was empty. So I ordered the small seal that the pump fits in and before installing it I used a small amount of silicone sealant on the seal and 6 months later, no leak. Hope this helps.
Old 03-25-2014, 12:55 AM
Ryank's Avatar
Rep:199
Well mine is finally fixed, finally took it into the dealership and used my lifetime warranty for the first time, they just put in a whole new tank, mine was cracked according to them! needless to say its fixed
Old 03-25-2014, 11:03 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Voonderbar! Thanks for the update!
Old 04-24-2014, 04:44 PM
Baal's Avatar
Baal Baal is offline
Vehicle: 09 Dodge Ram 1500
Trim Level: Crew Cab
Baal is on a distinguished road
Mine was leaking several months ago and I pulled the pump. Mine kind of twist locks into place and the design is not the best. Anyway, where the seal is I cleaned it up and added silicone sealant and carefully reinstalled. Waited a couple days to cure before refilling. No leaks!
Old 04-24-2014, 09:57 PM
Rep:2968
Voonderbar! Thanks for the tip.
Old 04-25-2014, 11:48 AM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
some tanks leak when the engine heats up and the tank expands. ask me how i learned this.
Old 04-26-2014, 12:18 AM
Rep:2968
Hey, huntergreen, how'd you learn that?!?
Old 08-09-2014, 09:42 AM
Trim Level: laramie
Default windshield tank leak
Here it is August and still no leak.
