How long before I can tow? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-28-2013, 11:37 AM
bdodge445 bdodge445 is offline
Vehicle: 1995 Dodge Ram
Trim Level: Laramie SLT
Color: Black/Gray
bdodge445 is on a distinguished road
Default How long before I can tow?
I just regeared to 4.56 today and I was wondering what y'all thought about how long before I can tow about 6k lbs? The gears I bought say "Drive easy for 500 miles, no towing for extended periods." I have to go pick up a car about 1000 miles away, should I be ok after the 500 mile break-in or should I go a little further than that. I know I'm going to get as many different answers as replies, but like I said, just looking for opinions
Old 06-28-2013, 01:11 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
You should be good to go after the 500 mile initial break in, just do push it within those 500 miles.
People don't usually wait at all if they tow trailers for a living, when I rebuilt the rear end in my GMC2500, I waited 10 miles before I hooked up my concrete pump (5500lbs), drove it for an additional 30k miles with no problems...
Old 06-28-2013, 01:53 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
You're talking metal-on-metal. Before roller cams went mainstream in production engines, it was the same deal for camshafts, and still is in older engines. Twenty minute break-in with no load, then let 'er rip. The break in time has to do with establishing the initial wear pattern and getting the surface worn to a nice polish and all the metal exchange has taken place.
Old 06-28-2013, 02:41 PM
DRX350's Avatar
Color: Blue-ish
Rep:118
huh, I thought we were talking gears here?
Old 06-28-2013, 02:48 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
I would wait 500 miles, per the instructions with your gears. Why risk the expense you made on re-gearing?
Old 06-28-2013, 03:16 PM
Color: Black/Gray
I wasn't asking if I needed the 500 mile break-in, I was wondering if 500 miles was enough to start towing. I wouldn't risk not breaking them in at all, weather or not it is really needed, better safe than sorry.
Old 06-28-2013, 03:20 PM
Color: Black/Gray
I am fairly certain that he was just using the break-in procedures for solid lifters as an example to show how metal on metal should be broke in
Old 06-28-2013, 05:17 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
As you said, the car is 1,000 miles away, I'm sure she'll be fine by the time you get there.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 06-28-2013, 05:31 PM
drp6982's Avatar
drp6982 drp6982 is offline
Vehicle: 2011 3500 SLT Diesel Dually
Trim Level: 3500 SLT
Rep:185
drp6982 has a spectacular aura aboutdrp6982 has a spectacular aura about
To be honest, I dont know why you have to wait to tow from a gear change
if installed properly and filled with fluid you are fine....
My Mopar Stable: 07 SRT8 Charger 440 Stroker with Direct Port Nitrous (1320ft - 9.18 @ 147mph)'
2014 Dodge Durango R/T Hemi
2012 Chrylser SRT8 300 Fully built 392 on 10Lbs of Boost
2011 Ram 3500 SLT Big Horn Dually
