Old 06-28-2013, 12:57 PM
Hntdeer Hntdeer is offline
Vehicle: 2013 ram
Color: Maximum steel
Rep:13
Hntdeer is on a distinguished road
Default Turning off seatbelt warning and beeping?
I just picked up my new truck last night and can't figure out how to shut the seatbelt warning and chime off doesn't say in the book at Least I can't find it that noise will drive me crazy I live in nh and we don't need to weare them thanks
Old 06-28-2013, 01:10 PM
02 Ram 02 Ram is offline
Vehicle: 02 Dodge Ram/92 IROC R/T
Trim Level: SLT Quad Cab
Color: Forest Green
Rep:67
02 Ram will become famous soon enough
The Enhanced Warning System (BeltAlert) can be enabled
or disabled by your authorized dealer or by
following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver's seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver's
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver's seat
belt remains unbuckled.
2002 Dodge Ram 4.7L
1992 Dodge Daytona IROC R/T 2.2 Turbo
Old 06-29-2013, 09:27 PM
Vehicle: 2013 ram
Rep:13
How do you do that with push button start
Old 06-29-2013, 10:08 PM
Color: Forest Green
Rep:67
LOL thats a good question. i googled that info and thats what came up. let me see what i can find gor ya
2002 Dodge Ram 4.7L
Old 06-29-2013, 10:10 PM
Color: Forest Green
Rep:67
here ya go
If you just push the start button without hitting the brake this should put the truck in ACC just as if it were a key. Once you do the below mentioned setup, the red seat belt light will still be lit, and the EVIC will still show the alert but the chime is disabled. Also doing the trick again will enable the chime again.
Do the following to disable it:
Start with the doors closed, ignition off. fasten your seat belt. push button to ACC mode with foot off the break 2 times, watch the seat belt light. when it goes off, unbuckle re-buckle the seat belt 3 times within 10 seconds, and immediately push button to off it will chime once to tell you if this was done successfully.
other guy said, this worked great but you have to press the start button twice with the foot off the break to get the seat belt light to illuminate on the dash.
2002 Dodge Ram 4.7L
Old 06-29-2013, 10:18 PM
newramkid newramkid is offline
Vehicle: 2014 1500
Trim Level: Limited
Color: GCM
Rep:17
newramkid is on a distinguished road
Originally Posted by 02 Ram View Post
here ya go
Somebody give that man some Rep Points!!!!
Old 06-29-2013, 10:25 PM
Color: Forest Green
Rep:67
nah LOL i googled it, then copy pasted it but thanks!
2002 Dodge Ram 4.7L
Old 06-29-2013, 10:28 PM
Vehicle: 2014 1500
Trim Level: Limited
Color: GCM
Rep:17
You helped a person out though when you didn't have to
(It's the little things that count)
Old 06-29-2013, 10:51 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Agreed! But, then again, this forum is full of some fine folks willing to do the little things. And that's what makes this forum great!
Old 06-30-2013, 12:12 AM
FeedMetal's Avatar
FeedMetal FeedMetal is offline
Color: Maximum Steel Metallic
Rep:83
FeedMetal will become famous soon enough
rep points for sure!!!! cant stand going around the corner and having to wear my seat belt or get nagged to death lol. THANK YOU!!!!!!!!!!!
'13 Sport Crew Cab / Hemi / 6-Speed / 3.55 / Anti-Spin - aFe Stage II CAI - MF 14" Muffler - BP 87mm TB - BP Catch Can
