Old 06-29-2013, 02:03 PM
cjm cjm is offline
Vehicle: 2012 1500
Trim Level: Big Horn Loaded
cjm is on a distinguished road
Default ? size for rear diff plug
I'm wanting to change the rear diff fluid on my 12 1500. Does anyone know what size wrench the plugs take?
They are bigger than any I have, so I'll have to go buy... don't want to waste time trying a bunch
Thanks much
Old 06-29-2013, 09:29 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
9/16" Hex bit socket, or a allen wrench.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 06-30-2013, 04:22 AM
Rep:2657
I so dislike the stock differential cover
sure you can check it to see if it is close to full BUT
there is no way to drain it without removing the whole rear cover
my Rams after market differential has a magnetic drain plug
i don't need to pull the differential cover unless i see metal filings on the drain plug
Old 06-30-2013, 07:39 PM
oldhp's Avatar
Color: WHITE
Rep:902
GT, Don't you have drain plug on the right bottom side of differential?
How would you know?
Old 06-30-2013, 08:49 PM
Rep:2657
my 2009 Ram had no drain plug in the 9.25 AAM rear diffential, like in this image, but not chromed
http://www.ebay.com/itm/JEEP-DODGE-R...e93c57&vxp=mtr
the OEM 2011 cover was even worse, it had to be filled from the front plate, until they discovered that the fill hole was TOO low & had a recall that put a fill plug into the rear plate
http://www.yourcovers.com/diff_cover...swaybar_lg.jpg
the cover that i have now, it has a fill plug, magnetic drain plug, a temperature sensor port, & a dip stick
http://mag-hytec.com/store/index.php...products_id=26
Old 06-30-2013, 10:54 PM
oldhp's Avatar
Color: WHITE
Rep:902
Ok, that makes sense. I forgot I have the "ZF" axle. It has the drain and fill plugs on the right side of differential case.
How would you know?
Old 07-03-2013, 09:48 PM
cjm cjm is offline
Vehicle: 2012 1500
Thanks for the info, it got me on the right track.. and for the Canadians... it's 14mm.... God, why did we do that!
