Old 06-29-2013, 04:46 PM
DanTheMan DanTheMan is offline
Vehicle: 1998 Dodge Ram 1500 Sport
Rep:23
DanTheMan is on a distinguished road
Default Rough idle.. Help!
I've had the problem ever since I bought the truck back in August, and its just been getting slightly worse and worse as time goes on.
Truck is a 1998 5.9L 4x4 with just under 170,000 miles
Okay, so the problem: about 2-3 minutes after I start it, the RPM's will drop down to around 500 or so, and it just doesn't want to run at all. when the RPM's drop, a loud hissing noise starts under the hood that is coming from the air intake.
If you are driving and the problem starts, it still doesn't want to rev at all. When you hit the gas, the RPM's will go up slightly, but then go straight back down. And if you keep your foot on the gas, it will start to pop and backfire. If you put your foot all the way down, it will downshift and the RPM's will jump up and the problem will go away for the rest of the trip.
If the truck sits for about a half hour or longer without running, the problem will occur every time you start it. It does it worse when it is hot outside or when the engine is already warm. Over the winter when it was really cold outside, the problem didn't really happen.
I tried a new idle air controller with no change. Any help would be great. Thanks in advance!
Old 07-04-2013, 11:05 AM
Rep:23
Also I've noticed when driving with the A/C on and I go up a hill, the AC will cut out until I get to the top of the hill
Old 07-04-2013, 01:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Sounds like the IAC on the back of the throttle body. Around $40.
Old 07-04-2013, 02:23 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
This video will confirm Warlock's diagnosis which sounds spot on.
Old 07-05-2013, 01:10 PM
Vehicle: 95
Rep:1776
It may be a defective IAC that you replaced it with.
I'd take it back and try another. If not, then I'd lean towards an upstream 02 sensor.
Old 07-05-2013, 01:13 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Check your fuel pressure.
Old 07-06-2013, 03:28 PM
Rep:23
Fuel pressure checked out just fine. Just did another IAC today, and nothing changed
Old 07-06-2013, 05:40 PM
Vehicle: 95
Rep:1776
Unplug your upstream 02 sensors and reset the ECM. Then try it.
Old 07-07-2013, 12:00 PM
DRX350's Avatar
Color: Blue-ish
Rep:118
No CEL?
if you have the opportunity, run a scope on the TPS, could be off, but not enough to trigger a CEL.
Old 07-10-2013, 03:17 PM
Rep:23
Update: got the new O2 sensor(finally) shipped in from Advanced, threw it on and all is well. No more hints of the problem. Thank you everyone for your help!
idle, rough
