Rough idle.. Help! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-10-2013, 03:23 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Upstream 02 sensor huh? Thanks for posting your resolution
Old 07-11-2013, 11:40 AM
DanTheMan DanTheMan is offline
Vehicle: 1998 Dodge Ram 1500 Sport
Rep:23
DanTheMan is on a distinguished road
Yes sir. Pulled the upstream, and it was almost completely black. Put the new one on and all is good. Now to find out how to pop the back one off without breaking any more tools...
Old 07-11-2013, 04:49 PM
Vehicle: 95
Rep:1776
Cut the wires and use a boxed end wrench.
Old 07-12-2013, 02:09 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Try using a tube wrench or a socket wrench. That'll give you more bite on the nut.
Old 07-12-2013, 11:01 AM
Vehicle: 95
Rep:1776
Default Rough idle resolved
I gave you some rep points for posting up, but I wanted to get back to this thread and post a resolved title to help other members.
Just a side note: The black hydrocarbons on the 02 sensor may have been caused by the defective (original) IAC causing it to go bad (prematurely?). In any event, nice to see you got her running smooth.
Old 07-12-2013, 03:56 PM
Rep:23
I wanna thank everyone again. That problem has been eating at me for the better part of 10 months. How would I post it as resolved? Or did you beat me to it?
Old 07-12-2013, 04:27 PM
Vehicle: 95
Rep:1776
As long as you post your resolution anyone doing a search for "rough Idle" it will locate your resolution because your thread will come up.
I posted a title "rough idle resolved" that should likewise come up under a search. And now that I typed it 2 more times it should come up.
It is an example of why the issue should be used when posting a problem as opposed to "WTF"
Old 07-12-2013, 05:26 PM
v8only v8only is offline
Vehicle: 2001 Ram 5.9 4x4
v8only is on a distinguished road
interesting..i have a rough idle..but not as bad as yours...its rough at start then smooths out mostly..i just passed smog..but ill try changing the 02 out..is the upstream one the furthest? does your ac still cut out heavy throttle? mine goes to the upper vents..was told vacuum issue
Old 07-12-2013, 06:42 PM
Rep:2968
When you say heavy throttle, do you mean WOT? (Wide Open Throttle) It's designed that way. When you punch it, you're asking for all the power the engine has. So the computer shuts off the a/c to give you as much power as possible.
Old 07-14-2013, 12:17 AM
Rep:23
Upstream is the one before the Cat. Thats the one I changed and the problem is no more. I originally thought vacuum leak, and thats what numerous friends said that looked at it. But the O2 was the trick
idle, rough
