Old 06-29-2013, 06:32 PM
Ballentx462's Avatar
Ballentx462 Ballentx462 is offline
Vehicle: 2009 Dodge Ram cc
Trim Level: Lonestar
Color: Grey
Ballentx462 is on a distinguished road
Default Door won't unlock
I am having some trouble getting my rear passenger side door to unlock. To unlock it I had to push the button like 3 times and now it doesn't work at all. Sometimes it's hard to even pull the lock up. I have the door panel off right now and nothing is rubbing against it to keep it from moving. Does anyone know where the lock motor is or have had this problem? I can see where the little metal bar goes across that connects it all, but I can't see where it goes into anything to make it move. I'd like to get it fixed today while I have the door panel off so I don't look ghetto opening the front door to unlock the back one to get my kid out
Old 06-29-2013, 06:34 PM
Color: Grey
Also it should be in my profile, but the truck is an 09 crew cab.
Old 07-01-2013, 10:36 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
The electric lock is built in to the latchassembly. Try putting some goob penitratiing oil in the latch assembly to see if it loosens up for you.
Old 07-28-2013, 03:39 AM
msfps04's Avatar
msfps04 msfps04 is offline
Vehicle: 2009 Dodge
Trim Level: Sport CrewCab
msfps04 is on a distinguished road
I got the same problem with the driver door. I'll let you know if I find something.
Old 07-28-2013, 12:40 PM
red041500 red041500 is offline
Vehicle: 2009 ram 1500 crew cab
Color: bright silver
Rep:22
red041500 is on a distinguished road
have the same problem with the same door on my 09 crew cab, dealer said its a bad latch assembly, they will warranty it next oil change for me under my extended warranty..
Old 07-30-2013, 03:59 PM
Trim Level: sport
Color: green
Rep:643
i have an rcsb, so can't recall if the back doors have key access, but would't using the key free it up?
Old 07-31-2013, 12:04 PM
ram1500fan's Avatar
ram1500fan ram1500fan is offline
Trim Level: Laramie Limited
ram1500fan is on a distinguished road
Mine had the same problem a while back. Dealer replaced lock actuator and I haven't had any problems since.
Tim
2009 Ram 1500 Laramie Limited, 2012 Jeep Liberty Limited Jet
Old 07-31-2013, 09:25 PM
will36 will36 is offline
Vehicle: 2010 R/T RAM
Trim Level: R/T
Color: BLUE
Rep:274
will36 is a jewel in the roughwill36 is a jewel in the roughwill36 is a jewel in the rough
Its the latch. Might as well change it out. We change them out all the time.
Old 08-16-2013, 03:01 PM
CallMeClay's Avatar
CallMeClay CallMeClay is offline
Color: Inferno Red
CallMeClay is on a distinguished road
Mine does the exact same thing! Same door and everything. When I changed out the speakers I checked to see if I could notice anything and I didnt see anything.
*Stock suspension on 305/55/20 Terra Grapplers*Flowmaster Exhaust*K&N CAI....uhh...thats about it :(
Old 08-23-2013, 06:48 PM
johnsrt4 johnsrt4 is offline
Vehicle: 2014 dodge ram 1500 5.7 hemi
Color: blue
johnsrt4 is on a distinguished road
mine is at the dealer I just bought it from for my pass. side door on reg cab. its the actuator. I read some where if its not under warranty for you you can pick one up from a junk yard and many jeep and dodge use the same actuator google it that's how I found that information.
