Old 06-29-2013, 06:53 PM
dtsrt dtsrt is offline
Vehicle: 2013 Dodge Ram Laramie
Trim Level: laramie
dtsrt is on a distinguished road
Default Air ride question
I have noticed while being outside the truck, engine and power off, that I will hear the air ride pump kick on occasionally. I am doing nothing that would change the load in the truck bed.
Wondering if anyone else has heard their air ride system do this?
Maybe a small leak in the line(s)?
Normal deal?
Thanks.
Old 06-29-2013, 09:26 PM
Timmyturbo Timmyturbo is offline
Vehicle: 2013 Ram Crew Cab
Color: Mineral Gray
Timmyturbo is on a distinguished road
Mine has done this occasionally but it is bleeding off, not raising. I assume from the increase in air pressure due to the heat since the ambient temperature is hot.
Old 06-30-2013, 04:37 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
From page 407 of the Owner's Manual: "After the engine is turned off, it may be noticed that the air suspension system operates briefly, this is normal. The system is correcting the position of the vehicle to ensure a proper appearance."
Old 06-30-2013, 09:34 AM
Dvp16's Avatar
Dvp16 Dvp16 is offline
Vehicle: 2013 Ram Laramie Longhorn
Trim Level: Longhorn
Dvp16 is on a distinguished road
Mine does this also. Seems is it just leveling out. Been keeping an eye on it because I only have about 2 inches of clearance in and out of the garage and I don't want to rip off the sat radio antenna.
Old 06-30-2013, 11:18 AM
blkramsport2k13 blkramsport2k13 is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: maximum steel metallic
blkramsport2k13 is on a distinguished road
Mine does it also
Old 06-30-2013, 03:13 PM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
Normal for any factory air suspension system to adjust after it rests.
(This is why I get to re-do (= money in my pocket) many alignments on Land Rovers, because not all shops realize the suspension will adjust itself on the rack for a certain amount of time after the engine is off, unless it's put into tight-tolerance mode.)
Old 06-30-2013, 07:00 PM
Tcon Tcon is offline
Vehicle: 2013 Ram 1500 QC 4x4 Sport
Rep:49
Tcon is on a distinguished road
I dropped my truck into entry/exit mode last night. I was on a slight grade, I think it didn't like that much and immediately reverted back to normal ride height.
Not sure what that was about, I'll ask the dealer when I go in. Their canned response is "yeah, that's supposed to do that." That's the response for everything, either that or "we can't".
5.7L/8 Spd/3.92/Air Ride - Whited Out Badges - S&B CAI, 87MM TB, BT Catch Can, Magnaflow 22", Magnaflow Y Pipe, Weathertech Vent Visors, White 3" Stubby Antenna, DeeZee Tailgate Assist, Bak Flip G2
Old 06-30-2013, 09:32 PM
UpToNoGood's Avatar
UpToNoGood UpToNoGood is offline
Vehicle: 2014 Ram EcoDiesel
Rep:61
UpToNoGood will become famous soon enough
I turned off my truck Thursday morning and it hasn't ran since. Today being Sunday I was outside my truck and the air ride kicked in for no reason. I wonder how long after the truck has been off that they can link the above quote together with the truck auto correcting.
2014 1500 Laramie Longhorn CC 4x4 8spd, 3.92 EcoDiesel - Hammerhead rear bumper sprayed with Linex - Iron Cross steps sprayed with Linex - Trucks cover tool box/Tonneau Cover combo - Geno's cabin filter - 275-65-20 Nitto Terra Grappler - Air Lift 1000
Old 07-02-2013, 12:45 AM
Rep:264
I wonder if the ambient temperature is affecting the "proper appearance"? Mines in my garage and I don't remember mine making adjustments the day after I parked it or later. Usually it's just the first 10-15 minutes after turning it off.
Old 07-03-2013, 08:54 PM
Trim Level: laramie
Thanks for all the replies. I should have searched the manual first. But nice to know it seems to be a normal function.
