Old 06-29-2013, 07:11 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Default 2012 ram sport loud crack noise when i start off sounds like rear end ?
2012 ram sport with a 6" rcx lift , Just went threw one ordeal now another , so rcx sent me adjustable control arms to correct my rear pinion issue and now yesterday I noticed a loud pop/crack noise when I move forward from a dead stop sounds like the rear end ? or possibly something else back there everything seems tight and the u joints were only replaced 2 weeks ago . I have read something about a recall on a pinion nut in the rear end is this also in the 2012 ? once I get the truck moving I hear nothing at all everything seems ok . But as I mentioned from a dead stop for the first second is sounds horrible ! I should also mention that my 2012 only has 12000 kms on it .
Old 06-30-2013, 05:04 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
i get a wired sound like that , sounds like its under my seat, i got it after i did the body lift so i didnt really worry about it...sad part is after you mod everything makes you nervous lol...my 11 had the recall, they checked it out last week and mine was fine.
2011 Hemi RCSB Sport 4x4
Old 06-30-2013, 05:12 PM
Rep:94
Did a few things today I think I solved the problem , I sprayed the rear coil springs down with rust check , and re torqued all the rear control arms and now the noise is gone thank god !
Old 06-30-2013, 06:48 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
Loose rear control arm. Happened to me when I installed my coil spacers
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 07-01-2013, 12:33 PM
Rep:94
Ya chances are it was where I had the new upper control arms installed , I did get almost a full turn on each of the bolts ..
Old 07-02-2013, 06:06 AM
Vehicle: 2011 Ram
Rep:141
at least thats out of the way haha
