Old 06-30-2013, 07:29 AM
pfenga pfenga is offline
Vehicle: 2001 Ram2500
Trim Level: laramie SLT
Color: blue
pfenga is on a distinguished road
Default 01 2500
problem with transfer case,59 gas 2500 np 241HD,put in low range,got ok lite, went a few feet to make sure engaged, towed vehicle out of hole and now t case locked.in 4wd,had shifter off and lever on case will only move into 4wlow,4wh, any help would be greatly appreciated,as is my only vehicle! pete
Old 07-06-2013, 11:53 AM
damnkidd012 damnkidd012 is offline
Vehicle: 97 ram 2500
Trim Level: base
Color: green
damnkidd012 is on a distinguished road
Try it while moving backwards slowly in neutral
Old 07-06-2013, 12:45 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Mine sticks in 4wd every now and then, with foot on brake, shift from drive, to reverse, and back to drive. Then shift it to neutral and try to move the selector back to 2wd...
Good luck
Old 07-10-2013, 04:21 PM
Color: blue
Default Drx350
thanx for reply-i tried all that and then some, have pulled front driveshaft out and disconnnected shifter,verify smooth movement,but lever on case is locked, it will only move about an inch,just far enough to get out of four low,it disengages low, but is still in four hi,the front drive vacum is disconnecting front axle,but you can hear tcase whining in four wheel,trying to get ideas, is only vehicle,can't be without my ram! pete.
