Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Towing
Towing 1st Gen Dodge Ram Towing Questions
Old 06-30-2013, 09:25 AM
teknoge3k teknoge3k is offline
Vehicle: 2003 Dodge Ram
Color: Dark Blue
teknoge3k is on a distinguished road
Lightbulb How do you tow?
Now this may be a simple question to most, and it's not intended to be silly. I know as much about automobiles as I do programming a space ship for NASA. So please, be gentle.
I have a 2003 Dodge Ram 2500 with a Hemi. It's a quad cab, with a full bed. I have the tow package on my truck, and a brake box. I am pulling a 8,000 camper (travel trailer), and want to know exactly how everyone pulls. Do you just keep it in drive? Do you turn O/D off? What about going up hills/mountains? I want to be as gentle as I can on my truck all while getting the job done. I have the Magnaflow exhaust and it makes my truck sound like it's going to explode when I am towing. I know that's just the loud muffler though.
Thoughts??
Old 06-30-2013, 09:38 AM
hydrex's Avatar
hydrex hydrex is online now
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
OD off. If it feels like it's lugging on a hill, I might downshift manually. Hemis develop their power at higher rpms, it won't hurt to run a 4,000 rpms or more. I tow a 10,000 lb 32' fifth wheel with my 1500 Ram hemi, it does a decent job. I might downshift going down hills to save the brakes a bit also. I think you'll be fine. I once towed a 28' boat (8,000 lbs) from Toronto to Maine in a blizzard, 4wd all the way, fingerprints still on the steering wheel.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 06-30-2013, 09:41 AM
Color: Dark Blue
Thanks so much for your help. That's how I did it (I only towed once when I picked the camper up).. I am glad I did it correctly, and that's the way to do it. Thanks again!!
Old 07-07-2013, 09:36 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
Thoughts??
I had a 2008 2500 with the Hemi and it would drop down a gear if I was going up a long hill. But for what you have 3/4 ton with Hemi 8000 lbs isn't going to hurt it. You can find the max weights on the drivers side door for factory recommendations.
Old 07-07-2013, 10:00 PM
Rep:2642
does the 2500 models have a tow/haul mode ?
If not, shifting manually will indeed help the transmission
if the gear you select keeps down & up shifting, go down one more gear
down shifting works well on down hill grades too, it uses the engine to help with braking, called compression braking
