tonneaucovered.com
Old 06-30-2013, 12:20 PM
Kweigand89 Kweigand89 is offline
Vehicle: 2013 dodge ram
Kweigand89 is on a distinguished road
Default 2013 ram 1500 suspension lift
Just wondering if anyone has done the suspension lift and what kind they went with?looking into getting one but not sure which one
Old 06-30-2013, 03:42 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:649
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
I saw a lifted 2013 on the way back from visiting my brother in College Station this morning, so I know its been done. That said, I have not and will not be lifting mine. I don't think there would be any difference between a 2013 and a 2009-2012 regarding which lifts will fit though unless you have air suspension. But then again there could be due to the electric power steering.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 06-30-2013, 04:21 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2095
If you get a lift for your 2013 make sure it's a '12 and up lift. They require different differential drop brackets and a different front drive shaft spacer.
If you're on a budget then the Rough Country kit with Bilsteins is a great option. If you want to step it up a notch BDS also makes a great kit. I would check out some of the threads in the 4th gen lifted section of the forum. All of that information is applicable to your 2013.
