Old 06-30-2013, 05:40 PM
mugapug mugapug is offline
Vehicle: 2011 dodge 1500
mugapug is on a distinguished road
Default Wheel offset question.
I have searched and searched the site with no definite answer so I have no choice but to ask. I see all the posts saying you can run 35 12.5 20 on 9 inches wheels If you use 1/4 inch spacers. My question is what offset is equal to 1/4 inch spacers. My math is a wheel with plus 1 is the same as the factory plus 19 with spacers. If I'm wrong please let me know. Thanks
Old 06-30-2013, 05:52 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
If I'm reading your question correctly you are asking what wheel offset would be the same as stock w/ 1/4" spacers? The answer would be +13 mm, roughly. 1/4" = 6 mm.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 06-30-2013, 07:00 PM
Default Wheel
You understand me perfectly. So if I have a set of positive 1 offset I will be able to run 35 12.5 20 with just the leveling
Old 06-30-2013, 10:13 PM
RAM EM's Avatar
Color: Grey
Rep:195
As far as them fitting I can't answer that, might be a good idea to ask in the lifted or leveled section. I can tell you that, if using the same width wheel as stock, the +1 mm wheels will "stick out" a hair under 3/4" more. Just under 1/2" more than stock w/spacers would be another way of looking at it.
Old 07-02-2013, 04:14 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
As RAM EM said, 1/4" spacers are approximately 6mm think which put the stock 20x9's at a +13 offset. With the wheels you want being +1 offset you will have no problems at all (provided you have a leveling kit).
I'm running 20x9 -12 offset wheels with 35x12.5" Toyo MT's. There's a link in my signature below with lots of pictures and information on how far they stick out etc. You might find it worth taking a look.
Old 07-02-2013, 08:24 PM
Default Very nice
Your truck looks good but man they look close. Have you put any weight in it or towed a heavy trailer? Your pictures are the most detailed I have seen
Old 07-02-2013, 09:23 PM
Rep:2032
Thanks! They definitely are close on the front.... But I have fixed the rubbing up there. The back isn't a problem at all.
I have hauled my dads racecar on a flat deck trailer (approx 4500 pounds) but I have the airlift 1000 bags in the back. So it doesn't sag at all. Here's a thread on that: http://www.ramforumz.com/showthread.php?t=142443
Old 07-04-2013, 08:26 PM
Default Pic
You are the man when it comes to detailed info thanks for your help
Old 07-04-2013, 09:21 PM
Rep:2032
Haha, thanks. I try to be as detailed as I can to help people out.
Good luck getting everything installed. Be sure to post some pictures when you're done.
