Old 07-01-2013, 01:40 AM
macc08's Avatar
macc08 macc08 is offline
Rep:722
Default Torque Values
Just wondering if anyone knew off hand, or has access to the torque values of the bolts/nuts during the level install, ie wheels, sway bar nuts, control arm, etc.
any info is appreciated!
thanks!
Old 07-01-2013, 09:03 AM
GAltima GAltima is offline
Vehicle: 2010 Ram 1500
Rep:40
GAltima is on a distinguished road
These are the specs from the install sheet from the Hell Bent Steel leveling kit.
Shock absorber-to-lower arm nut and bolt - 155 ft-lbs
Stabilizer bar-to-link nut - 75 ft-lbs
Tie-rod end nut - 45 ft-lbs
Upper ball joint nut - 50 ft-lbs
Upper strut mounting nuts - 45 ft-lbs
Wheel lug nuts 120-150 ft-lbs
Old 07-01-2013, 09:04 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
that's good info right there! Reps!
