Old 07-01-2013, 03:04 PM
jakethasnake jakethasnake is offline
Vehicle: 2010 Dodge ram Laramie
Color: Blacked out
jakethasnake is on a distinguished road
Default Spacers all around
So last year I ha my truck leveled under the impression that they would do just the front, but the local 4x4 shop did all four coil sprins so it still has the rake but lets me fit my tires. I was wondering if it was possible to add bilstens 5100 shocks to a truck that was already leveled safely? Also would removibg the rear spacer be a hard project?
Old 07-01-2013, 05:12 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
No, don't combine a spacer and the adjustable shocks.
removing the spacers would not be that difficult. a couple hour job if you have basic shop tools.
Old 07-03-2013, 11:24 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:379
This. ^^^
Can't do it. One or the other.
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Goodyear Duratracs. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector. More AR's than you can shake an AK at.
Old 07-03-2013, 01:32 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Yup, exactly what the two gentlemen above said. You can't stack leveling kits and Bilsteins. Your CV shaft and A-arm angles would be ridiculous and not work at all.
As gonefishin776 said, removing the rear spacer is not hard at all. All you need to do is jack up the truck, support the frame with jackstands, remove the lower shock bolts and sway bar links, drop the rear end (be mindful of the brake lines), and remove the coils and then take the spacer off them. Literally can be done in about half an hour if you know what you're doing.
Old 07-03-2013, 01:35 PM
Grubrunner's Avatar
Rep:3883
This is one of the strangest things I've heard.....
Did you ever confront them?
Grub out!
Old 07-03-2013, 01:45 PM
justbilly's Avatar
justbilly justbilly is offline
Vehicle: 2012 ram 1500
Color: tequila sunrise
justbilly is on a distinguished road
The rough country leveling kit comes with front and rear spacers. That's probably what they put on his. I've got the same kit but left the rear spacers off... truck sits almost dead level.
Old 07-03-2013, 01:46 PM
Grubrunner's Avatar
Rep:3883
Okay, gotcha.
Thanks.
Grub out!
