Strange Noise....? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 07-02-2013, 11:37 AM
SupermanWV SupermanWV is offline
Vehicle: 2013 RAM 1500 4x4
Trim Level: Express Quad Cab
Color: Copperhead Pearle
SupermanWV is on a distinguished road
Default Strange Noise....?
I bought my truck brand new (2013 Ram 1500 Express Quad Cab 4x4 5.7L with 3.92 and Limited Slip Diff). I've never had a limited slip axle before so this may be normal.....
When I'm going straight and accelerating kind of hard/hard, I hear a brief chattering sound (doesn't really sound like metal to metal) but it only lasts a second or so, and then it stops (also stops if I let off the accelerator). But if I keep accelerating it will happen again but only for a second. So its not a noise that happens constantly, but it only does it if I'm in gear and moving forward regardless of speed, if I accelerate and drop into lower gear for passing it happens. Does not happen if in Park and press accelerator or if in nuetral and press accelerator.
Is this just the sound of the limited slip kicking in while accelerating?
Or is it a problem. It does usually happen if taking off from stop and hitting accelerator to get going quickly, or if I'm moving slowly and punch throttle to take off quicker... but it is more towards the end of accelerating when the gear is about to change (automatic tranny).
I have never been turning in these situations...always going straight.
Thanks for any info you can give.
Clark (SupermanWV)
Old 07-02-2013, 12:36 PM
Asur Asur is offline
Vehicle: .
Rep:4373
The chatter your hearing is probably the anti-slip kicking in, it used the ABS system to drag on the brakes of the wheel that is loosing grip, that chatter is the master pumping that particular brake assembly. JMO but think this is all your experiencing.
Old 07-02-2013, 12:42 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
azur seems to hve answered your question, my question would be, what is causing the anti spin to activate so often this time of year?
Old 07-02-2013, 02:12 PM
Vehicle: .
Rep:4373
I think that the member is as he so indicated in his OP
" It does usually happen if taking off from stop and hitting accelerator to get going quickly, or if I'm moving slowly and punch throttle to take off quicker.",,
The hemi's got some good power, probably spinning the wheels on take off. Might what to try it on wet pavement to see if it does it more, or a dirt road.
Old 07-02-2013, 03:06 PM
On my way home I tried going fast again to see what happens. Well it did it again. And I remained going fast and the chatter just kept going till I had to slow down. I've never had this happen before in a truck. But I've never had 3.92 gears and a limited slip before.
It kinda makes me nervous.
Clark (SupermanWV)
Old 07-02-2013, 03:14 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
I'd run it by my dealer and have them take a quick look at it, it sure can't hurt any.
Besides if the document it, and you have a problem later you may be covered.
Just an idea.
Vehicle: .
Rep:4373
are you in 4x4 mode? Just asking
Old 07-02-2013, 04:22 PM
Not in 4x4. And even does it with Traction control turned off. The more I listen to it. It may be coming from front to middle of truck. Like maybe the torque controller.
Do they vibrate?
Clark (SupermanWV)
Old 07-02-2013, 04:49 PM
Vehicle: .
Rep:4373
Think you should drop into the dealer and make sure you can reproduce it easy, and don't take "its normal" unless they show you why it does it.
Old 07-04-2013, 12:18 AM
12RamSport1500's Avatar
12RamSport1500 12RamSport1500 is offline
Vehicle: 2012 Ram 1500
Color: Mineral grey
Rep:17
12RamSport1500 is on a distinguished road
I have the same sound but only between 1-2 and have the traction control off on a harder acceleration. When I have the traction control on it doesn't do it.
18" Magnaflow, S&B CAI, Diablo I-1000, Weathertechs
