Old 07-02-2013, 12:50 PM
Tcon Tcon is offline
Vehicle: 2013 Ram 1500 QC 4x4 Sport
Rep:49
Tcon is on a distinguished road
Default Air Suspension (Wheel/Tire Upgrades that fit)
I have searched the forums and while I have found scattered information on the biggest tire sizes that fit the trucks equipped with the air suspension. I thought I'd try to start this thread to get anybody with those upgrades to post anything taller or wider than stock that fit. Even if it is a larger offset or with spacers. I am hoping to get a consolidated thread to help the others like me trying to figure out what sizes I can upgrade to.
The majority of what I have seen is 275/65R20, a slightly taller tire. Has anybody had success with taller or wider tires?
Thanks in advance!
5.7L/8 Spd/3.92/Air Ride - Whited Out Badges - S&B CAI, 87MM TB, BT Catch Can, Magnaflow 22", Magnaflow Y Pipe, Weathertech Vent Visors, White 3" Stubby Antenna, DeeZee Tailgate Assist, Bak Flip G2
Old 07-02-2013, 04:35 PM
spoiler's Avatar
spoiler spoiler is offline
Rep:364
I don't have air suspension... I did drop my truck using a 2/3 Groundforce kit and am now running 305 45 22 tires on 22 x 9.5 rims. no touch,rub,or bottom out.
My truck came with 17 x 7 rims stock
I only chime in to let let you know there is quite a bit of room under those wells even when lowered a couple inches.
Looking back my comments may be of no use to you bet there it is.
Old 07-02-2013, 10:24 PM
Rep:49
Thanks for your information but the air suspension has a different set of requirements. People talk about rubbing at entry/exit, some don't have it and others have it "fixed".
I'm just hoping to get a consolidated consensus of tolerances for the air ride.
Old 07-03-2013, 10:29 AM
JCC11 JCC11 is offline
Vehicle: 2013 RAM & 2014 RAM (ordered)
Trim Level: Laramie Limited(s)
Rep:20
JCC11 is on a distinguished road
Great topic. This is info I'm looking for as well. Let's get the tire intel rolling!
Old 08-11-2013, 01:13 PM
Rep:20
Thanks in advance!
Any new information on this topic?
Old 08-14-2013, 03:29 AM
NeverEnuff's Avatar
NeverEnuff NeverEnuff is offline
Vehicle: 2014 Ram
Rep:87
NeverEnuff will become famous soon enough
I'm running 305/45/22's on a 22x9.5 wheel with 15mm bs. Only rubs in entry/exit mode
Old 08-14-2013, 01:04 PM
Rep:20
Ok, that's good info. Your wheel/tire combination is:
-- 1 3/8" wider and 0.2" shorter than the stock setup.
Old 08-21-2013, 12:29 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
I'm running 275 65R20 BFG All-Terrain TA KOs. My stock Goodyears rubbed the front left liner very slightly in entry mode. MY BFGs rubbed quite a bit in entry position and very slightly in normal mode. I think it has more to do with the liner having a lot of play in it. I can push it in a good two inches. It is also very soft plastic or rubber so it doesn't seem to hurt it any. All it has done after 2 months is slightly polished the spot where it rubs.
I have since bought a heat gun and have softened up the spot that rubs and pushed it in. It isn't pretty in there, but so far no rubbing at all now in entry mode with my BFGs. I have about 1/2" between the tire and liner now. Prior to modifying the liner, I couldn't get a piece of paper in there. Now I can fit my finger in there.
Old 08-26-2013, 12:53 AM
Alter Ego Trip Alter Ego Trip is offline
Vehicle: 2013 Laramie Limited
Trim Level: Limited
Rep:42
Alter Ego Trip is on a distinguished road
How bad does it rub? I'm looking at changing wheels out to a 20x9 with 0 offset, sticking with stock tires for now.
If my math is correct your tire is 32.79" in tall. The stock tire is 32.97" tall.
I'm looking at a 9" wide wheel with 0 offset compared to your 9.5" wheel with 15mm offset. That would mean the 0 offset wheel would stick out about .8 of an inch further on a .19 " taller tire.
Old 10-24-2013, 11:09 PM
Jeevan Jeevan is offline
Vehicle: 2013 ram 1500 longhorn
Trim Level: Longhorn
Jeevan is on a distinguished road
hey there would it be possible to run a 22x10 with a offset of 20 mm
and what would the tire size be ?
