Old 07-02-2013, 06:07 PM
pfenga pfenga is offline
Vehicle: 2001 Ram2500
Trim Level: laramie SLT
Color: blue
pfenga is on a distinguished road
Default transfer case popped?
01 2500 5.9 gas- 241 DHD transfer case-second time in 4wlow, pulled buddy out of mud, shifted back, o no, shifter stuck, only moves far enough to disengage low, stays in 4wh, puts lite on dash out. have front shaft out,linkage off,and detent spring and piston removed,lever on t-case only moves 1", your forum has briefly covered a bad snapring? trying to drill down into this as is my only transportation and would like to avoid extended down time, and by the way, you guys rock, have been on diff forums, but as heavy-equip tech-you guys have it all!thanks in advance-pete
