Old 07-02-2013, 06:43 PM
Shadowmustang Shadowmustang is offline
Vehicle: 2001 Dodge Ram 1500
Color: green
Shadowmustang is on a distinguished road
Unhappy Desperate! 2001 Dodge Ram 1500 5.9l cylinder 6 misfire with ticking sound
Just replaced cylinder heads that cracked. Had to get new heads. Replaced plugs at the same time. Did not replace wires, distributor cap or rotor. Only misfires on #6, as it happens that was a rocker arm bolt that was hard to tighten. Didn't replace rocker arms or push rods. I need to figure this thing out right the first time very low on money as I am living on a VA pension. Very limited income, this will have to come out of food money. Tried getting one of those light up spark plug testers, it wouldn't fit in the plug wire. Also oil level is remaining constant so I don't think it is the plenum gasket. I am open to any and all suggestions.
PS. Truck ran well 3 days before getting P0306 code. Only did short trips prior to having to go 30 miles for a doctors appointment. Ran well on the way there and acted up on the way back.
Old 07-02-2013, 09:31 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
A few things come to mind. Number 6's stubborn rocker. It may be that it isn't down all the way. This can lead to the matching valve not opening fully or at all. Second, oil consumption is not so obvious when a plenum gasket fails. It starts out small. As the gasket fails, the leak gets bigger. Then the mis-firing and rattling starts. Third. Ticking, immediately after head replacement makes me think the head gasket did not seal on number 6. I've had that happen twice in my life of working with Mopar smallblocks. No obvious reason. Pulled them back down, put in another gasket on the offending side, and all was good. Despite the fact that the head gasket is the deepest, in light of the recent head replacement, I'd suspect that first. Make sure the #6 wire is firing the plug. Make sure the plug is firing. If they are OK, I would pull the spark plug and start the engine. Does the ticking stop? If so, dead cylinder. How does the mix smell as it shoots out? A little like coolant? Head gasket.
