Old 07-02-2013, 09:27 PM
Jollux Jollux is offline
Vehicle: 1997 Ram 1500 360
Jollux is on a distinguished road
Unhappy 1997 Ram Misfire Codes P0300 P0305, P0308
Im getting the below misfire codes, usually happens when first starting up truck, if engine is already warm and i clear the codes and start it up and drive it again this issue doesnt seem to happen. Truck does run slightly ruff on cold startup but not to the point of it stalling or anything, truck has lost of power, doesnt smoke or leak anything. Codes are below
P0300 - Random Misfire
P0305 - Cylinder 5 Misfire
P0308 - Cylinder 8 Misfire
I have ran fuel injector cleaner through truck - Didnt Help
I have changed spark plugs to Champion with proper gapping, noticed old plugs were all over the place with wrong gappings but didnt notice anything strange with old plugs, oil, white plugs etc etc
I changed distributor cap and rotor, all plugs looked fine when i did this, made sure plugs were put back to the proper terminals. (BTW the digram to do this blows because if you notice cylinder 2 and 7 are straight forward not like the pictures online show where the cap is slightly twisted!!!)
After doing all the above i am still having the same problem! Thought about changing out spart plug wiring but dont think that is the problem.
Noticed today there is vaccum line broken (bottom left of throttle body - looking at it from the front, not sure what this is for or if it could be part of my problem?)
Any other ideas of what i should check or replace. Possibly coil pack?
Please respond with any ideas, thanks in advance
Old 07-03-2013, 01:09 AM
Vehicle: N/A
Rep:1045
vacuum leaks can certainly cause those codes. try fixing that and see where it gets you. fyi if you ever run a seafoam treatment, that vacuum line you mentioned being broken is best to feed everything equally.
another thing off the top of my head is 0 sensors... they'll pop that series of codes if they're bad or disconnected.
hope it all works out for ya...
Old 07-03-2013, 09:34 AM
Thanks I will try this I also found a TSB about rerouting spark plug wires as they could cross arc anyone heard of this before?
Old 07-03-2013, 12:14 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Yuuup. I was reading your OP and working my way down to suggest you reroute the wires. Then I got to the part where you found the TSB.
Old 07-03-2013, 03:00 PM
Vehicle: N/A
Rep:1045
did you do it on yours drew? I had a solid 250,000 on my 2nd Gen and never had to reroute mine
Old 07-06-2013, 04:00 PM
Vehicle: 95
Rep:1776
I've never had a problem with the wires on mine Jaron. But I've seen it on a couple where they rub a little and the white powder is a dead give-away.
(P.S. 218,000)
Old 07-07-2013, 10:22 PM
MAD IRISHMAN's Avatar
MAD IRISHMAN MAD IRISHMAN is offline
Vehicle: 1998 and 97 Dodge Ram 1500
Trim Level: Work Package
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
MAD IRISHMAN is on a distinguished road
I did everything on mine from plugs, wires, sensors, both O2's, Distributor, Coil, etc etc, to include the plenum Pan gasket. Turned out being a valve prob. Leak Down test ASAP. I replaced the heads and was good. (But im a new guy. got my info from this Forum) and it worked awesome.
Old 07-07-2013, 10:31 PM
I fixed my vacuum lines today and started to move the wiring, mainly i moved the coil wire away from the other lines on the left side of the engine, didnt have enough time to do the rest of the wiring. Reset the PCM and went for a test drive, check engine line did not come on for 30 minutes, ran a little better and i still got a p0300 and p0305 code, however the p0308 code is gone. Yes that is the side where i moved the wire, so now i will try the reroute for cylinder 5 wire and see if this helps.
Old 07-07-2013, 10:33 PM
FYI.... definetly still not running right, forgot to add took it on highway, when i tryed to go faster than 60 mph giving it the extra throttle caused big misfires!!! Could this still be an exhaust issue as welll with a catalytic converter?
Old 07-07-2013, 10:44 PM
From my experience after replacing the CAT, I was able to fend off the 03-Whatever code while on a highway for a while as long as i was getting on it, As soon as i got off and was at idle, BOOM! I chased this for a year. Did you look down your throttle body yet? See a pool of oil?
