Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-04-2013, 05:32 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
Default steering gearbox play
Hey everyone,
I have some slop in my steering, enough to make me uncomfortable on the interstate. It has oversized tires but just barely, and no lift kit. I checked and the ball joints and tie rods look good. and I replaced the steering damper about a year ago. So my question is; how much play should there be where the steering column enters the gear box? I can twist mine at least 45 degrees before anything happens at the tires. Just for kicks I adjusted the box (loosened the nut on top and tightened the allen screw inside the nut). Turned it in about a full turn and it helped, but only some. If I go any further the wheels won't self-center after a turn. Time for a new gear box? Would grabbing one from a salvage yard be a waist of time?
Thanks, and happy 4th!
-Mac
Old 07-04-2013, 05:35 PM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
Oops, wrong forum. Sorry guys
Old 07-07-2013, 03:05 PM
SOFpirate SOFpirate is offline
Vehicle: 1997 Dodge Ram 1500 SLT 4x4
SOFpirate is on a distinguished road
I would look at the bushings on the ends. The OEM ones after a while tend to wear out. I suggest replacing them with nylon washers or something that doesn't give.
Old 07-24-2013, 08:26 PM
nepats1992's Avatar
nepats1992 nepats1992 is offline
Vehicle: 1995 Dodge Ram 1500 SLT
Trim Level: Slt
Rep:12
nepats1992 is on a distinguished road
Also, check your Pitman Arm. My 95 had a similar problem, and that's what caused it. They're relatively inexpensive as well.
