Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 07-04-2013, 04:34 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
Default Loose steering
Hey everyone,
I have some slop in my steering, enough to make me uncomfortable on the interstate. It has oversized tires but just barely, and no lift kit. I checked and the ball joints and tie rods look good. and I replaced the steering damper about a year ago. So my question is; how much play should there be where the steering column enters the gear box? I can twist mine at least 45 degrees before anything happens at the tires. Just for kicks I adjusted the box (loosened the nut on top and tightened the allen screw inside the nut). Turned it in about a full turn and it helped, but only some. If I go any further the wheels won't self-center after a turn. Time for a new gear box? Would grabbing one from a salvage yard be a waist of time?
Thanks, and happy 4th!
-Mac
Old 07-04-2013, 04:48 PM
ninjalogic's Avatar
ninjalogic ninjalogic is offline
Vehicle: Dont Own A Dodge Anymore
Rep:12
ninjalogic is on a distinguished road
www.RockSolidRamTruckSteering.com
Old 07-05-2013, 11:43 AM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
Thanks man, I'll look into this. I did replace the steering shaft about a year ago but didn't know about the bearing.
I'm still wondering how much play I should have at the actual gear box before the pitman arm moves. Oh, and I also replaced the track bar and links.
