Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-22-2013, 07:50 AM
ginifh ginifh is offline
Vehicle: 2006 dodge ram 1500
Color: red
ginifh is on a distinguished road
Unhappy Dodge ram 1500 Felt like slipped a gear
Was trying to come home on hwy last night, truck felt like it slipped a gear then began making a terrible noise...which got louder when we accellerated. Felt like the truck was dragging and then a terrible smell came from it. No check engine light came on. Checked Transmission fluid which was low and added some, still did the same thing on the way back to house. Is it possible there is a leak in the vaccum hose, this would cause drag and smell wouldnt it? Any ideas or suggestions would be great...need help asap!!!
Old 09-22-2013, 11:42 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If it was low on fluid it can cause the transmission to slip, but it doesn't usually happen out of the blue at cruising speeds. (in my experience)
There aren't any aspects of your transmission that are vacuum activated.
#1 How low was it?
#2 Was it running hot?
#3 Does it have an external transmission cooler other than the cooling in the transmission cooler in the radiator? (almost confusing double-talk)
#4 Is there any leakage where the back of the motor stops and the transmission begins?
P.S. Make sure you have sufficient coolant in the radiator and the expansion tank (overflow/reservoir)
