Old 07-20-2013, 01:54 AM
sinfulrelations's Avatar
sinfulrelations sinfulrelations is offline
Vehicle: 1994 dodge ram 2500
Color: maroon and silver
sinfulrelations is on a distinguished road
No I'm getting +12 at the asd relay coil has +5
Old 07-22-2013, 03:30 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
I'd run a jumper from the battery to the coil (disconnect the factory harness from the positive side to avoid any feedback/overload issues). With 12V going to the coil, see if it'll fire.
Old 08-29-2013, 10:40 AM
if i power up the coil like that i get spark still no start, one thing i did notice it that when i turn the key on the check engine light looks weak, like the battery is dying but i get the full 12 volts at the battery, could i have a bad ground in the wiring harness? if i do where can i find a wiring diagram?
Old 08-29-2013, 08:03 PM
Rep:85
Power at the coil, good fuel pressure. Sounds like distributor. Bad ground is always possible, but you're getting 12V where you need it.
Old 09-21-2013, 12:53 PM
WE HAVE FIRE!!!
i did some looking and started testing the grounds, there was a broken wire on the drivers side of the motor, put a new end on it re attached it to the motor and she ran!
Old 09-21-2013, 01:44 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Voonderbar!!!
Old 09-21-2013, 02:35 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I have to side with RRJ on this, AND STICK TO THE BASICS, forget about the fuses. If the coil (5 volts is perfect) is getting power in and not out it COULD be the coil. However, check the plug itself and make sure it's good. Did you check it for ground on the other side? Then I'd move to the coil pick-up.
Check the engine ground to the firewall for corrosion and check the terminals on the battery etc. Never hurts to clean and coat them.
If you want to check the fuses, go ahead. While you're doing that have someone check the air pressure in the tires, and maybe clean the windows.
Thunms up
