Old 09-29-2013, 09:49 PM
walightner's Avatar
walightner walightner is offline
Vehicle: 1999 Dodge Ram
walightner is on a distinguished road
Send a message via AIM to walightner Send a message via Skype™ to walightner
Default Steering Disaster
Ok, guys. I have a problem. My ram is lifted on 38s and I currently run stock steering gear/ pump. The problem is that my steering wheel will just freely spin with no feed back at the tires (very dangerous). This normally takes place between 20 mph and up. It has, however done it at lower speeds. When I originally did all the work on the truck, I put an AGR gear on it and it held up for a few months and then started do the "death slip". Due to lack of funds, I replaced it with a stock unit and it started slipping within the first 100 miles of its use. Could this be a pump issue or do I have to hunt down a better steering gear? Any help is appreciated!
[FONT="Comic Sans MS"][/FONT][CENTER][CENTER][/CENTER]Skyjacker 7" system, 3" body lift, 38x12.50 TSL SX's, Daytona Series 51 Steelies, 4.56 gears, Mag Hightec, Diff. Covers, Edelbrock Shortys, Air raid CAI, Throttle body spacer, Flowmaster 50 series cat-back, Shift Kit, External Tranny Cooler, Superchips Flashpac, 180 T-stat, MSD 6A Ignition, Blaster Coil, Plugs n' wires, Road Armor Stealth rear bumper, Smoked LED Taillights, SS Style hood, Billet Grill Inserts, Westin Nerf Bars, Fresh Paint.
[CENTER][/CENTER][SIGPIC][/SIGPIC]
[/CENTER]
Old 09-30-2013, 12:38 PM
1stRAM2012's Avatar
1stRAM2012 1stRAM2012 is offline
Vehicle: 2015 Ram 2500
Color: Black on Black on Black
Rep:123
1stRAM2012 will become famous soon enough1stRAM2012 will become famous soon enough
I would say its the gear...dont know what's causeing it to continue to fail though. Maybe needs a heavier duty gear. With a total of 10 in of lift what all did you change on your steering linkage.
MODS in profile
Old 10-01-2013, 11:53 PM
Deereman39's Avatar
Deereman39 Deereman39 is offline
Vehicle: 1996 Ram 2500 Laramie SLT
Trim Level: Laramie SLT
Deereman39 is on a distinguished road
Question Steering wonder
Has anyone used one of these steering gear brackets I see on line? If so did it help?
Thanks Ed
Old 10-02-2013, 09:00 AM
Wh1t3nukle's Avatar
Rep:55
Steering gear box can handle those tires for just street driving. You got an AGR gear box and did you talk to them? Warranty etc.?
What have you done with the power steering pump?
Bleeding the system can be a little bit of a tedious effort and recommended to be done with 2 people.
This reads more like a pump issue and assumes the rest of your steering is intact such as tie rod ends, adjusters, steering shaft, etc.
Can you put the front axle on jack stands and report what happens when turning lock to lock about 40 times? Look at the PS fluid level in the pump....
Old 10-12-2013, 03:51 AM
jabba974 jabba974 is offline
Vehicle: 1997 Dodge Ram 2500
Color: Driftwood Satin Metallic
jabba974 is on a distinguished road
Funny as it sounds...replace your power steering lines... and add a good quality steering stabilizer...
Old 10-12-2013, 08:29 AM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
Wow sounds like that would give you some dirty underwear... I would think this is a mechanical part failure not in the hydraulics. But, maybe I don't understand correctly.
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 10-13-2013, 02:46 PM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
It's hard to figure out what's going since you said it comes and goes sort of. If you had and problem with the pump or hydraulic system failure you would have no assist causing very hard steering at slow speeds. Also have also seen you will only get assist in one direction. Sounds more mechanical to me check your pitman arm. Is it installed properly and all the way possible loose or striped splines on the output shaft. Just my 2 cents. Def something wrong. Wish I could check it out and see.
Old 10-29-2013, 08:29 AM
R Pope R Pope is offline
Vehicle: 1995 and 1997 Ram
R Pope is on a distinguished road
DO NOT drive that truck until you find what is stripped! It has nothing to do with the hydraulics, it is a mechanical defect that will kill you and whoever you run over or in to.
